Marshall BB-2 faint signal
Started by Yorick, October 29, 2017, 08:58:13 AM
Yorick
I've got a Marshall bb-2 with a very faint signal. Everything works properly, the output signal is just very low. I've got limited electronic knowhow but I suspect one of the transistors (tr2 or tr3)  So before I start replacing working parts, does anyone know which one it is/had the same problem? :)
Edit: schematic added
Plexi
To you, buffered bypass sucks tone.
To me, it sucks my balls.
Steve.mg
Yorick,
Did you get it this way? Are you using Proper power supply or fresh battery? It it a fault the unit has developed?...etc...etc..
It is always better to say as much as you know and have tried to check yourself when you say:...?..It's broken..?.. It will be a good
learning experience to get to know the workings of what your using. Have you checked the plug mates only with the contacts it's
supposed to with the jack exposed [lid off!] Sounds like a part-short across the output..? If the Debugging hasn't helped you, let us
know what you tried to do...
Steve
