Maestro FZ-1S Super Fuzz - Filter / tone question
Started by andy-h-h, October 30, 2017, 05:00:20 AM
andy-h-h
Hello - first post...   have built a few toys recently and have just finished soldering up a Maestro Super Fuzz FZ-1S, and it sounds pretty cool.  I can understand very basic high / low pass filters, and I'm curious to know what is going on in this pedal.  What is going on with this filter - what is this kind of filter circuit called?
Sorry if this is covered elsewhere
Parts of it look like a sort of highpass, but I have to wonder if it is drawn (and redrawn) accurately.  There have been a number of errors in Maestro factory schems.  Not a LOT, but things that would throw someone off if they were attempting to clone from the original factory schem, and could not spot the illogic.
I was given an original FZ-1S board, rehoused it, and it sounded great.  A nice range of different sounds.  I'd comment on the sonic effect of the switch, but it seems to be missing at the moment.  I think I loaned it out to a guy down the street.  Now that I'm retired, I'm re-organizing all my space and gear, so I may well run into it, before I start harassing the guy.
Plexi
It remains me, in some way, to the high-pass stage w/fixed 'value' from the Big Muff tonestack, as Mark says
To you, buffered bypass sucks tone.
To me, it sucks my balls.
Steve.mg
Hey, I was wondering about Q5 and Q6... Never seen transistors wired up "that" way! Not sure they'd 'do' much (?)  :icon_rolleyes:
Steve
andy-h-h
Think Q5 and Q6 are acting as diodes in this configuration - why not just use diodes?  I don't know...
I think at some times and places, reject transistors were cheaper than diodes.
There's also the "10 transistor radio!" which had 6 actual transistors, a dud transistor for the detector diode, another for bias, and a few dud-duds soldered on to up the transistor count. (Later an FTC rules discouraged such shenanigans.) I don't remember seeing this on guitar gear however.
The R-C network *appears* to put a heavy cut on bass/mids, and a sharp rise on highs.
That would probably be ear-bleed after a diode-clipper, so I too wonder about a typo.
andy-h-h
It most definitely cuts bass pretty hard.   I was wondering if it was some kind of 2nd order filter or pre emphasis circuit.
andy-h-h
I tried another forum (electrical engineering) and the answer I received there was that without the capacitors this is a t-pad attenuator.  The capacitors / resistor part provides pre emphasis or top boost.
I think this is two stages of top boost based at around 1k with attenuation.
andy-h-h
I tried it on a breadboard running pink noise through the circuit and measuring the results on a spectrum analyser, and tested each stage of the filter  -  I'm pretty sure it is a 2nd order high pass filter with quite a high rolloff point (about 1k).
It hits 5.7dB/Oct.... simple filters don't get to 6dB/Oct until way way down/up the curve.
andy-h-h
Thanks - what did you use to produce that simulation?
