The Bare Box #3
Started by smallbearelec, November 12, 2017, 08:31:48 PM
smallbearelec
Eleca makes several pedals in this sheetmetal format, which they showed me at last NAMM.
I asked if I could buy them as kits, and I've been able to build and try out their tube pedal and envelope filter over the last few months. They also have a clone of the Big Muff. I like the effects well enough, but I actually got more interested in the possibilities of the platform itself.
It's roomy (5 7/8 x 4 1/8 x 2 3/4 at the top), thus easy to work in, and inexpensive because Eleca already makes it for their own offerings. I have ordered for first quarter of  '18 the unpainted enclosure drilled completely for a two-knob build. The kit will also include: a pad-per-hole perfboard (mounting studs are pre-installed), 3PDT stomp switch, jacks for input and output and DC power, a battery drawer and rubber feet. Twist my paw and I'll throw in a couple of push-on knobs. Based on the costs that I have been given, retail for the whole thing will be under $25.00. Add a few bucks for what to stuff the board with, and you have a full kit of your own choosing for not a lot of money. I hope it sparks some ideazz.
Regards
SD
digi2t
If you could get them undrilled, that would be a bonus.
I'm thinking awesome Harmonic Percolator box. :icon_wink:
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
Nice. It has a very old-school 60's pedal look. Or maybe stick wooden end cheeks on it and build your own moogerfooger!
Another vote for undrilled from me too - more flexible that way - although with only two holes it'd be easy enough to add a few more!
Tom
Plexi
Looks ultra robust
I like it
To you, buffered bypass sucks tone.
To me, it sucks my balls.
digi2t
Stick a slide switch on the side and voila!!, instant Superfuzz.  :icon_mrgreen:
Dead End FX
Steve sent me an Eleca Tube overdrive earlier this summer (thank you again!), built in the same chassis.  It's pretty robust, and roomy enough for multiple stompswitches.  I guess I should mention that there was room inside for a 12AX7, albeit on its side, although I imagine a rail of some sort would permit vertical installation of a pair of pre-amp tubes in the box.
brianq
#6
Quote from: digi2t on November 13, 2017, 06:19:12 AM
+100 it's screaming for a Harmonic Percolator, also thought of a Big Muff when I saw it, I kinda like these vintage oversized enclosures. I don't run a lot of pedals so I don't mind them being big?
Sent from my iPad using Tapatalk
smallbearelec
Quote from: ElectricDruid on November 13, 2017, 06:34:51 AM
Exactly. And the holes for the jacks and stomper are where you would logically want them anyway. If this turns out to sell well, I'll be happy to get a three-hole version and possibly pre-painted pieces as well. Parts kits for stuffing the board are also obvious. But I have to order 100-unit minimums, so I'm starting a little small to limit the hit to cash. We are not hurting; it's just that I learned from my experience with the Bare Box #1 that what I think will be a blockbuster might not be what the mass market wants.
Aph
Is there a square hole punched for the DC jack?
I like the bigger box... lots of room for adding that additional circuitry that you (me) forgot to put on your (my) original circuit board.  ;)
Tony Forestiere
Quote from: smallbearelec on November 12, 2017, 08:31:48 PM
Regards
SD
At your approximate price point of $25.00 for all of this, I think you have a winner.  :icon_biggrin:
smallbearelec
Quote from: Aph on November 13, 2017, 08:19:41 PM
Yes, and the exact height of the pre-installed studs combined with pre-drilled slots on the perfboard make for a precise fit.
glops
Love this enclosure, Steve. Will definitely purchase drilled. Would prefer undrilled but will buy either way!
Quote from: smallbearelec on November 13, 2017, 05:43:41 PM
To be clear, when I said "undrilled", I was only really referring to the front panel. I'm fine with holes for the jacks and power socket. I *know* I'm going to need those. What I'm not so sure about is how many knobs or switches on the panel this thing is going to need.
Thanks,
Tom
Ben N
Looks awesome, Steve, a little bit reminiscent of the old Ross stuff but without the recessed knobs. I would def be interested at that price, but  also think I would prefer an undrilled top, even if steel scares me a little. I can see using this for 2x stompers, like an OD with a boost, or a swirly thing with a LERA, for which the single centered stompswitch hole would be awkward. Maybe include with the kit a few drilling templates for common patterns, or just post them on your site as pdfs for downloading.
wavley
Quote from: ElectricDruid on November 15, 2017, 02:09:53 PM
I agree with this.  I might prefer the jacks to be at the back of the pedal on a box this big, but I'm not above putting hole plugs in a pre-drilled one and putting them in the back.  To me this screams russian big muff, I might like to build a backup that fits the same space of the one that's been on my board for twenty something years.
Thanks,
Tom
Bone is in the fingers.
EccoHollow Art & Sound
eccohollow.bandcamp.com
smallbearelec
We have stock!
http://www.smallbear-electronics.mybigcommerce.com/the-bare-box-3-platform-kit/
Shipping costs were a little higher than I expected, but I still think it's good value. Future runs will include drilled 3-knob, undrilled, etc.
I will be working on some builds in this version. Meanwhile, here is a .diy file for others to hack up:
http://diy.smallbearelec.com/Projects/BareBox3/BareBoardWithPower.zip
Regards
SD
