Isolated splitter question
Started by P-Trash, November 16, 2017, 06:04:37 AM
P-Trash
Hi. I want to built a hum-free splitter for two pedal chains (splitter out1->some guitar pedals->amp1; splitter out1->some other guitar pedals->amp2). Would this work fine in my case? http://www.geofex.com/FX_images/splitter.gif Can I leave only one isolated output and one direct output? And is this necessarily to add two batteries, or I can just use only 9v power supply?
antonis
First of all, Wellcome...  :icon_biggrin:
Second, let's make some corrections like from <splitter out1->some guitar pedals->amp1; splitter out1->some other guitar pedals->amp2> to <splitter out1->some guitar pedals->amp1; splitter out2->some other guitar pedals->amp2>
<Can I leave only one isolated output and one direct output?>
IMHO No, 'cause the "direct" output should share it's GND with both amps..
(but wait for R.G. to make things clear..)
<And is this necessarily to add two batteries, or I can just use only 9v power supply?>
Not necessary but advisable for more headroom..
In case of using only one 9V battery you have to create a +4.5V -4.5V "splitter" for zero volts reference point..
(but some op-amps doesn't work well with such a low possitive supply..)
You can alternatively form a voltage divider for +4.5V to connect the two 2M2 resistors (and an input coupling cap, of course) and power the Op-Amp from +9V & GND..
P-Trash
Hm, sounds more difficult then I expected. But thanks for the aswer anyway ;D
antonis
You're wellcome but I can't see any advanced difficulty.. :icon_wink:
At least, not such of the level of trying to "equalize" many amps & signal grounds..
