Vox v847A volume Mod and true bypass
Started by marcos_s_p, November 19, 2017, 09:53:09 PM
marcos_s_p
Hiya!
I´ve been quite a while wanting a volume pedal, but to build one you need a good housing, etc. So, I know that the VOX v847 can be modified to be a volume pedal (adding a switch to change from wah to volume and vice-versa). How about the v847A? However, I also heard that in that case the volume wouldn't go totally to silent, is it true? Is there a work around? Additionally, would the tone suck because of the whole circuit?
Another question is that the spdt switch of it went bad. I have a few DPDTs that I could use and wire as a SPDT. But them I could also wire to true bypass. Is it worth it? I heard that the output between effect and bypass would have a volume shift. Is that true?
Many thanks in advance!!!
Marcos
thermionix
QuoteHow about the v847A?
I would assume so.  Have you got a schematic?
QuoteI also heard that in that case the volume wouldn't go totally to silent, is it true?
Yes.
QuoteIs there a work around?
Not that I know of without messing up the wah part.
Quotewire to true bypass. Is it worth it?
Yes.
Quotea volume shift. Is that true?
Some people notice a volume drop when engaging a TB wah, it never bothered me on mine.
marcos_s_p
Thanks thermionix!
I'll look for the schematics, I don't have them at the top of my head. But maybe it will be easier to build one volume pedal. My difficulty is in the enclosure.
Quote from: thermionix on November 19, 2017, 11:30:43 PM
How messed up would be?
Many thanks again!!
Marcos
antonis
Can't see any problem other than Volume pedals use a relative low value pot (10k or so..)
