Author Topic: 9V to +-14v  (Read 4290 times)
armdnrdy
Re: 9V to +-14v
« Reply #100 on: February 14, 2018, 12:57:25 AM »
If you are referring to changing the circuit voltage with pots....
I believe that I mentioned early on that deviating from the stock CE-1 voltage of +14/0/-14 would change the LFO and the clock from the original.
It sounds like that is what you are encountering when you adjust the voltage.
More width may sound good in the vibrato setting...but not so much in the chorus.
If it sounds good to you....then it is good!
