Controlling ditto looper with micro-controller
Started by spoitras, January 03, 2018, 08:36:18 PM
spoitras
Hello,
I've replaced the footswtich on my ditto looper with a mini jack. So far, if I plug in a patch cable and short the tip to ground, I get the behaviour I normally expect from the footswitch on this pedal.
To control this with a micro-controller, I can think of three ways to proceed by essentially replacing the original switch with either:
  • an opto-isolator ic
  • a relay
  • an analog switch ic
Am I correct to assume these three options would function equally well? Would any of them be preferable? I would rather not use a relay if I can help it to keep the (mechanical) noise to a minimum... I'm mostly leaning towards the analog switch IC since I've used them before and I have a few on hand.
Any thoughts?
highwater
For the switch IC, there are two main concerns that I can think of:
1) Does it/can it leak DC into the signal path? If it does, you might have problems. If the signal pins need to be biased to a particular DC voltage, then it probably won't work at all.
2) What's the on resistance? Find a resistor near that value and connect it between tip and ground - if it still works, you should be fine with the IC.
"I had an unfortunate combination of a very high-end medium-size system, with a "low price" phono preamp (external; this was the decade when phono was obsolete)."
- PRR
spoitras
Quote from: highwater on January 03, 2018, 09:32:40 PM
Thanks, those are great points to consider.
I went for an opto-isolator in the end because I liked having all the control circuity in the pedal. This way, I can send 5v triggers from a micro-controller pedal or from my modular synth and the ditto will respond to both equally well. Works well on the breadboard, I'll try to solder it together this week.
I know you've completed this, but if the original pedal just uses a short-to-ground, that suggests to me that the switch is connected to a micro controller input. These typically have internal pull-ups, so the easiest way to add a switch is a short-to-ground. You can use an NPN transistor to short the input to ground in the same way - either instead, or in parallel with the switch. It doesn't need a relay. Essentially this is the same as your opto-isolator, except without the isolation!! If you're connecting it to a modular synth, you'd need a 10K to the tranny's base and a diode to ground to protect the tranny against negative inputs.
HTH,
Tom
spoitras
Quote from: ElectricDruid on January 07, 2018, 04:41:22 PM
Thanks Tom! That's certainly an elegant solution.
Am I wrong to be wary of doing without isolation in this case?
Sylvain
Quote from: spoitras on January 07, 2018, 08:47:52 PM
Sylvain
That's up to you, I guess. I've used the transistor solution on modular gear plenty of times, and I've tested whacking it with +20V signals and it survives that, so that was good enough for me. The opto-isolation keeps the grounds separate, which might sometimes be an advantage, but aside from that, I don't see any particular benefit to it.
Tom
