Author Topic: 1/4" jack socket intended for battery power switching (Not a TRS)?  (Read 148 times)
anotherjim
I'm building a kit bass at the moment (great fun BTW) and came across something I haven't seen before  :icon_eek:
The jack socket supplied is a round barrel type (like the ones in cable extension sockets but with longer threaded barrel).
The socket has 3 terminals so I assumed it was TRS. The bass isn't active, but I assumed they supplied these in case it is for switching the battery negative just like you do with stompbox input jacks.
Anyway, I continuity test the terminals with a TRS plug inserted.
What I assumed was the ring terminal made no connection to the plug ring.
If I withdrew the plug a few mm, the ring contact made.
At first I though "yeh, typical cheap crap". Because I was hoping to use it as TRS for a stereo output option. Damn.
Actually, it's a decent metal (non-ferrous ) construction.
Could it be purpose made with a second Sleeve contact for battery switching?
Maybe I haven't noticed any before because I wasn't looking, but does anyone know of source for similar, preferably panel mount ones?
And are there any TRS with an extra sleeve contact?
I'd search, if I knew what to search for ;)
"So lets stay within the limit of sureness: lets consider the fuses you have available and lets see what you have to do to light them up..." Farfisa Partner 15 drum machine manual.
YellowBoy
Re: 1/4" jack socket intended for battery power switching (Not a TRS)?
« Reply #1 on: January 12, 2018, 06:21:27 AM »
Are you sure it's not just a case of "typical cheap crap" as you say?
Does it look like this? Usually seen in some telecaster/LP copies...
The only switched jack sockets I've ever come across are the usual suspects...I reckon because the barrels are just too narrow to accommodate the mechanical switching bits and bobs.
antonis
« Reply #2 on: January 12, 2018, 07:35:07 AM »
Jim, maybe you use them with 6mm plug..
(silly, of course, but sometimes...)  :icon_redface:
« Last Edit: January 12, 2018, 07:36:39 AM by antonis »
Tired of updating my account to enable 3rd party hosting..
anotherjim
« Reply #4 on: January 12, 2018, 09:16:41 AM »
Yes, similar, but sleeve/case terminal is without the cable clamp.
& thinking about it - the usual chassis/pcb types don't have room for an extra sleeve contact.
I should make it clear that I was wondering about sockets with an addition sleeve contact which will intentionally miss the ring portion of a TRS jack. Most of them rely on sleeve contact via the aperture only - there is no actual contact "finger" used. I'm thinking of a contact similar to ring & tip in operation and similarly isolated with no plug inserted. If a TRS plug should be inserted, the ring conductor does not get connected unless the socket also has a ring contact in the usual place behind the tip.
Consider the effect of plugging a balanced TRS into an output with a 9v battery negative on the ring  :o
...Ah, found something...
This is what I have!
...and...
..This would work for TRS "stereo" AND switch a battery negative. It calls the Ring contact "Centre".
& I think I guessed right -  there is an additional sleeve contact and it should miss the ring.
