Boss Bypass Momentary Hack?
Started by thehallofshields, January 19, 2018, 02:58:27 AM
thehallofshields
Hey guys, a lot of digital pedals using micro-controllers for bypass offer toggle switches to go between Momentary / Latching modes.
If anyone has ideas on how to achieve that with a Boss type bypass, I'll gladly breadboard them and try them out.  :icon_razz:
break the connection between R41//C23 and C26//C27. connect instead R41//C27 to R48//C27, and that will only switch while you hold down. if your initial on is the wrong one, swap the connection over to the other transistor base.
thehallofshields
#2
Quote from: duck_arse on January 19, 2018, 09:05:03 AM
Awesome. I drew up what I think you are describing.
Used a DPDT On/On/On to get: Normally Bypassed | Latching | Normally Engaged
What do you think? Will it work? Overkill?
interesting - are you made of switches? I would have just used a single pole double throw - do you have a use for normally engaged?
and yes, that seems pretty much what I was thinking, have you tried it on the BB?
thehallofshields
Quote from: duck_arse on January 20, 2018, 08:35:14 AM
No I don't have a use for normally engaged; it's just theory crafting. If I were to build it I'd go with an SPDT and skip that option. I'd probably skip the Zener Diode too.
blackieNYC
Guys, this is great. I had been recently exploring ways of doing this - mom switch, latching switch, and switch between. And the (slow) JFET switch seems to be the best way of silently, or perhaps smoothly, switching an audio path while audio is actually passing.
thehallofshields
#6
Quote from: blackieNYC on January 21, 2018, 10:32:40 AM
Absolutely. Noiseless, soft-touch switching with some flexibility.
I could see it being very useful for Oct-Up, Tremolo, Noise Effects etc.
The only problem is we're looking at 8 Transistors to implement it.
-- 2 BJT for the Flipflop
-- 1 BJT for the LED
-- 3 JFET for the Bypass
-- 2 BJT for the Buffers
blackieNYC
Built this, using BC182s then BC547s. (Just like the lower drawing-just lighting the LED) I have it working in normal Boss mode, alternating on, off, with each button press.
    It misses a switch about 1 out of 15 closures.  I've used all the values in the first drawing. What might I need to do?
In momentary-effect-insert-mode, I'm getting no momentary response - one output is On, one is Off. They will respond to the first button press, then they are done. Is it possible we have a flaw?
"..connect instead R41//C27..."  Do you mean C27 here, or just C23?
yes, I think I do. R41/R42/C23 provide the pulse or the pull-up. connected to C26 and C27, they [should] toggle, connected to either R48/C27 OR R47/C26, they will pull-up normally open, pull down when pressed. turns out, no I don't.
ahhh - I see now - there is one thing I missed to say - remove R48, and switch to that base for momentary. sorry about that.
thehallofshields
I'll gladly redraw the schem if you guys get it to work.
blackieNYC
R48 - cool, thanks.
I also need to figure out why mine is working "almost consistently".  I'll post some voltages.
thehallofshields
Just curious, what type of switch are you using?
blackieNYC
Usually I must admit I'm touching a wires together, but for this I happen to have a very nice momentary stomp.
Still need to sit back down to the breadboard, make duck's change, and record some voltages.  I must be out of tolerance with a part or my transistors are a poor substitute.
I don't want to mention the value changes on the circuit I built all that time ago, because they are only minor, one up and one down-like. I've always found the flip-flops, in every version I've tried, from all the manufs, to be a little not-100% on test on BB.
blackieNYC
#14
Quote from: duck_arse on January 27, 2018, 08:37:35 AM
As in, prone to noise/errors until you put in inside an enclosure?
Momentary function is perfect now - remove R48 and attach the switch circuit there instead of where the caps meet.  I can also remove R47, leave them both out, and get momentary insert on the base of Q7, and momentary removal on Q8.
