Author Topic: AMZ Q&D 2.0 compressor  (Read 113 times)
« on: February 11, 2018, 03:42:54 PM »
I've built this using schematics from AMZ site, but I made my own PCB to avoid wiring and have a possibility to use SMD chip. It works, but there is some kind of noise that is more audible at tone decay. Everything seems fine, connections are OK, solder joints too.
What I am not sure about this build is grounding - shall analog / digital ground be connected together, or not? I have connected them together.
This is my PCB:
« Last Edit: February 11, 2018, 03:49:42 PM by rankot »
Ampegulator, Bassballs, Bazz Fuss, Bearhug Compressor, Bronx Cheer, Clean Sweep, Demeter Compulator, Electra Distortion, Engineer's Thumb, Hybrid Fuzz, Orange Squeezer, ProCo Rat, Ross Compressor, Valvecaster, 6J6, SFT 2, Ugly Face, more to come...
blackieNYC
Re: AMZ Q&D 2.0 compressor
« Reply #1 on: February 11, 2018, 06:50:23 PM »
Can you describe this noise a little more?  As the note fades?
There is of course a noise gate in the Q&D. That might be complicating your problem.
Thing Modulator, Magnus Modulus +,Meathead, 4049er,Great Destroyer,Scrambler+, para EQ, Azabache, two-loop mix/blend, Slow Gear, Phase Royal, Escobedo PWM, Uglyface, Jawari,Corruptor,Tri-Vibe,Battery Warmers
