I still loathe the effort of clear coating, but I love the effect of acetone
Started by EBK, March 13, 2018, 09:29:09 AM
if I might add my 0.02 dollarpounds* - don't use plastic knobs on good looking lumps of wood.
* tariff/s may apply.
Quote from: duck_arse on March 15, 2018, 09:43:15 AM
Don't worry.  I'll probably go with shiny aluminum.
I have some knobs made out of ebony that I thought of using, but they are too dark for this enclosure, in my opinion.  I'll take a look at what other wooden knobs are available.
Update:  Oooooh.
http://www.dknob.com/skhtm/cherry.html
$18 each though.
Another, much cheaper $8.95 ea. plus $19.99 shipping:
https://www.libertyamps.com/collections/knobs/products/cherry-hardwood-knob
If you couldn't tell, I'm searching at the moment for knobs made from cherry, with a set screw, for 1/4-inch pots.
I think I'll keep these knobs on it.
Now that it looks good, I just need to keep optimizing it to make it sound less like something is wrong with the circuit.  :icon_wink:
Quote from: EBK on March 18, 2018, 01:52:52 PM
Good call, looks killer!  8) So how did the copper shielding tape work out? No noise issues?
Well, I didnt try it without the shielding, so I can't make a comparison, but there is no noticeable noise with it.  It works the same as any metal enclosure.
antonis
Alright, I'm officially sold. As soon as I confirm the circuit I want in there I'm picking up a couple boxes.
Quote from: vigilante397 on March 19, 2018, 09:25:24 AM
You'll want to pick up some L11 jacks (or another long bushing jack) for these, by the way.
Quote from: antonis on March 19, 2018, 07:39:38 AM
LED on a wooden box...??????   :o >:( :icon_mad: :icon_mrgreen:
I have apparently commited a sacrilege.  Help me out here.  "It would have been much better to use ________."  :icon_confused:
Quote from: EBK on March 19, 2018, 09:37:30 AM
Ah, good to know. Thicker walls and whatnot. Did you have any issue with the bushing on the pots, or are standard Alpha bushings long enough to get through?
I didn't want to say anything, so thanks, antonis.
Quote"It would have been much better to use metal, like a chrome bezel/holder, maybe."
but it looks good.
diffeq
Quote from: EBK on March 19, 2018, 09:48:01 AM
A small light bulb inside fresnel lens. Or one of those nixie tube dots: https://tubes-store.com/product_info.php?products_id=969
[Edit] Just checked the voltage requirements for those tubes, not exactly pedal-friendly (unless one uses voltage multiplier)
Quote from: vigilante397 on March 19, 2018, 09:50:26 AM
I used standard Alpha pots.  No problems.
thermionix
If it's a theremin, where are the antennae?  Do the two knobs control pitch and volume?
Quote from: thermionix on March 19, 2018, 08:41:59 PM
The knobs control fuzz/theremin mix and volume.
It's not really a theremin, but rather a frequency tracking oscillator with some overshoot that makes it sound theremin-like.  Pitch is controlled by the frequency of the input.
Quote from: duck_arse on March 19, 2018, 09:53:00 AM
but it looks good.
Is this better, or does it look bad?
The nut is threaded onto a collar made out of heat shrink tubing.
