No Signal out of FET - Troubleshooting Help
Started by BuddyPrince, March 17, 2018, 06:48:06 PM
antonis
#20
Quote from: BuddyPrince on March 20, 2018, 05:23:13 PM
However, I'm still left with the question, how do I get the source voltage down to 4.5v?  The bias voltage seems to be int he right range...
You have to set it by Drain current and Source resistor value..
(VS = ID X RS..)
Biasing Gate to a given voltage VG and for a desired quiescent Drain current ID, you can estimate Source resistance value needed from transfer characteristics curve of your specific MosFet..
(taking in mind that Source voltage VS should be slightly more than VTH below VG..)
e.g. For a desired ID of 1mA at VGS of 3V with 4k7 Source resistor, Gate bias voltage should be on 7.7V for a VS of 4.7V..
(provided  VTH < 3V..)
P.S.
It may help to figure it as an BJT Emitter follower of much larger VBE and almost infinite hFE..
MaxPower
How about using a pot as the source resistor and adjusting it until you get the desired voltage? Or do you have to muck about with the drain resistance as well?
What lies behind us and what lies before us are tiny matters, compared to what lies within us - Emerson
antonis
In case of pot use, it should be better to be used for Gate bias purpose..
MaxPower
Gah, the op amp mixer keeps looking better doesn't it?
antonis
BuddyPrince
Quote from: antonis on March 21, 2018, 07:51:19 AM
(VS = ID X RS..)
P.S.
Thanks Antonis!  My next question, how do I determine the desired drain current?  Is it related to the output current of the instrument? Do I need to bias each MOSFET with the appropriate resistor to get VS to be consistent across each MOSFET?
MaxPower
From the datasheet I'm guessing. The specs RG posted for example. Just a guess though.
antonis
#27
Quote from: BuddyPrince on March 22, 2018, 03:31:04 PM
That should be your FIRST question..!! :icon_biggrin:
When designing an amp, either CS or CD(Source follower), we first take in mind output current (load requirements) which current shouldn't be more than quiescent current (steady current due to DC bias..)
e.g. if you bias each of your followers for a 1mA quiescent Drain current (at half the supply voltage), maximum Drain working(total) current shouldn't exceed 2mA..
(actually, Drain quiescent current should be 10-15% greater than maximum Drain current due to signal peaks..)
so,
Yes..!!  :icon_wink:
Determine your load current needs and decide for your Drain-Source current..
(which isn't difficult for a Source follower with gain less than unity and Source resistor much lower than load driven..)
Of course..!!
(although it took me some time to realize you're talking about Source resistors..) :icon_redface:
Each transistor has it's own Source & Output and I'm sure you don't want to mix them up..
Long-tail pair("troika" in your case) doesn't apply to Source followers..
(It might apply to Common Source amps of identical (copy-paste) FETs - more on this written by W. Shakespere "Midsummer Night's Dream", 1595/96..) :icon_biggrin:
P.S.
In case you're talking about only one(common) bias resistor for all three Mosfets,the answer is still YES..!!
(FEts exibit wide parameter spread, even among identical items, so using only one bias source shouldn't work..)
antonis
#28
I might confused you a bit so let's face it on paper..
A Source follower exibits a voltage gain of unity (let's keep 0.05 - 0.03 difference as safety margin)..
Biased at 4.5V, it needs a signal peak greater than 4.5V to clip (Voltage DC+AC level up to Supply voltage magnitude)..
As far as our signal peak is lower than the voltage our Source is biased at, we don't have to worry about..
That given, we now have to worry about load current need for maximun voltage swing..
For a load of 47k, say, and a signal Vp of 4.5V, say again, our load "draws" slightly less than 100μA..
That leads to work with Drain quiescent current of 200μA (or more)..
For that current, we need a 22k5 Source resistor to have a quiescent Source voltage of 4.5V..
We know search for VGS appropriate to give 200μA Drain current..
Let's say that VGS is 2.3V, for a VDS of 4.5V..
So, VG should stand on 4.5+2.3=6.8V..
We need a voltage divider of R1/R2=0.755 (actual values due to PS current consumption availiability..)
Summarizing, we place a 22k5 Source resistor, we set Gate voltage at 6.8V and voila..!!  :icon_wink:
P.S.
The above is just a bias rule of thumb with arbitrary taken values..
More close to your case should be to work with 3k3 to 4k7 Source resistor, about 1mA Drain current (more or less) and a trim pot for individul Mosfet VGS setting but I leave it on you as an implementation task.. :icon_wink:
(in case of your circuit won't work you'll be able to find the reason(s)..)
MaxPower
Holy hell, op amps are cool! Seriously though, those are some great posts (Paul, RG, Antonis).  Lots of great info. My copy of Electronic Principles glosses over Jfets and mosfets.
BuddyPrince
Awesome! Thanks guys!  I'm going to work on digesting and implementing these things...
Will update as progress happens...
;D
BuddyPrince
Well...I got the JFETs I had wanted from the get go, soldered them in, and got my circuit working.
I deeply deeply appreciate all the knowledge you all have shared with me!  I feel like I have a much stronger understanding of biasing in general, and JFETs and MOSFETs in particular.  No doubt my knowledge is still quite elementary, but it's better than before.
Thanks everyone, in particular R.G., PRR and Antonis!
antonis
Quote from: BuddyPrince on March 26, 2018, 06:29:55 PM
So we've here a great lucky beggar...!!  :icon_biggrin:
(I shouldn't ever dare to dream of a JFET working circuit without socketing & trimming..)
Glad to hear your circuit works, BudduPrince.. :icon_wink:
