A useful tool
Started by Mark Hammer, April 02, 2018, 02:44:43 PM
blackieNYC
Looks pretty useful, as you say, but I already have one of these:
http://www.peakelec.co.uk/acatalog/dca55-peak-atlas-dca-semiconductor-component-analyser.html
Also a nice bit of kit. The best thing is you can connect the probes up any way you like and it works out which one is which and then tells you, instead of the reverse!
Tom
So, in answer to Allan's question, it appears yours does measure leakage, whereas the one Joe was thrilled about doesn't.  At least the E-bay blurb doesn't mention leakage-testing.
Yes, that's correct - DCA55 gives leakage current at the tested current.
T.
