Super-Simple Reverb Circuit
Started by freebird1127, October 26, 2003, 04:10:22 AM
freebird1127
Hey guys,
    I'm looking for the easiest (YET GOOD SOUNDING) reverb circuit I can find.  It's for incorporation into a guitar pre-amp I'm building for a power head.  It should run off of a 15 VDC power supply, so If op-amps are involved, ***CMOS ONLY PLEASE***
    Also, where should I place the reverb circuit?  I would assume after any tone controls, does that sound right?  I think it'll be a baxandall...
Thanks again, Ciao!   :D
Evan Haklar
Evan Haklar
What's the difference between incompetence and indifference?  I don't know and I don't care!
The easiest good sounding reverb circuit you can find is the driver/recovery for a spring unit. Two dual opamps will do that one.
freebird1127
Quote from: R.G.The easiest good sounding reverb circuit you can find is the driver/recovery for a spring unit.
R.G.,
Do you have a schematic for this?
Evan Haklar
Evan Haklar
Aharon
There's one known to work at JD's site here:
http://www.generalguitargadgets.com/v2/index.php?option=displaypage&Itemid=142&op=page&SubMenu=
I just built it an posted a short report.
One drawback of the new forum format seems to be that people don't get to read them for some reason.                :(
   Cheers.
Aharon :D
Aharon
Peter Snowberg
If I were to put that that design together with CMOS opamps, I would still use an NE5532 for the tank driver. The 5532 is able to drive heavy loads and a reverb tank sure qualifies there. There are few pieces of modern recorded music that havn't passed through at least one 5532.
-Peter
Eschew paradigm obfuscation
Paul Perry (Frostwave)
Quote from: AharonOne drawback of the new forum format seems to be that people don't get to read them for some reason.                :(
  Aharon :D
Which is why, if you are replying to something raised on a post, but it has nothing to do with the thread, you should make a brand new post (possibly referring to the original). It's driving me mad!!! but, of course, this board is in every other way FANTASTIC!! thanks Aron!
Aharon
Quote from: Paul Perry (Frostwave)
  Aharon :D
Hi PAul.I thought it had something to do with the original question cause it would just be a matter of a small adjustment to use 5532s or similar.
I wasn't complaining either.
Of course the forum is amazing,in the last week alone I got like three new builds.
Take care
Aharon :o
Aharon
