TL071 for TL072?
Started by zener, November 12, 2003, 06:58:33 AM
zener
Can I always substitute TL071 for TL072? Is there any significant difference? I'm eyeing the AMZ Overdrive Pro to build and it has TL072 but what I have is TL071.
Thanks  :wink:
Oh yeah!
Peter Snowberg
TL071 is a single opamp and the TL072 is a dual opamp. You can use two TL071s in place of a single TL072 with some wiring, or you can use 1/2 of a TL072 in place of a TL071 with some wiring, but they are NOT pin for pin compatible. The TL074 is a quad opamp if you see those.
See these links for more:
http://focus.ti.com/docs/prod/productfolder.jhtml?genericPartNumber=TL071
http://focus.ti.com/docs/prod/productfolder.jhtml?genericPartNumber=TL072
http://focus.ti.com/docs/prod/productfolder.jhtml?genericPartNumber=TL074
-Peter
Eschew paradigm obfuscation
bettycat
Quote from: Peter SnowbergTL071 is a single opamp and the TL072 is a dual opamp. You can use two TL071s in place of a single TL072 with some wiring, or you can use 1/2 of a TL072 in place of a TL071 with some wiring, but they are NOT pin for pin compatible.
What the man said !
@Peter: This is the shortest and best explanation I have ever seen, great !
David
Peter:  Don't forget that if you just use one of the op-amps in a dual chip, you need to ground out the inputs of the unused one.  In one of my very early breadboard experiments, I didn't do this and I managed to smoke a TL082.
Peter Snowberg
Very good point David. Thanks. :)
I've never smoked an opamp this way, but maybe I'm just lucky. You always want to keep the inputs at the same voltage.
