|AMPAGE| |GEOFEX| |AMZ|
May 22, 2013, 05:34:30 AM
891285 Posts in 97594 Topics by 28689 Members
Latest Member: 4floorsofwhores
Home Help Login Register
DIYstompboxes.com  |  DIY Stompboxes  |  Building your own stompbox  |  Boss DS-1 Seeing Eye Mod 0 Members and 1 Guest are viewing this topic. « previous next »
Pages: [1] Go Down Print
Author Topic: Boss DS-1 Seeing Eye Mod  (Read 1759 times)
Arn C.
« on: December 10, 2003, 02:57:31 PM »
I just finished modding my DS1 to the Seeing Eye Mod.
I changed C1,C5,C12 to .1uf metal film
"      "       C2,C8,C9,C14 to 1uf Metal Film
"      "       C7  to 220pf silver mica
and I replaced the check led to 3mm clear blue led (I didn't make it a 5mm because I didn't want to drill out the hole.
Is that all there is to it or should I do more?
Arn C.
Logged
phillip
WWW
« Reply #1 on: December 10, 2003, 06:59:57 PM »
How does it sound?
Phillip
Logged
Ansil
Guest
« Reply #2 on: December 10, 2003, 07:50:09 PM »
geocities.com/austenfantanio/DS
that is a drawing of it.
Logged
LH
« Reply #3 on: December 10, 2003, 08:39:51 PM »
There's a bit more to it.
http://www.robertkeeley.com/audio6l6/dstech.html
Logged
KevinSTP
« Reply #4 on: December 10, 2003, 09:11:44 PM »
Hi Arn;
     I have been following the same topic here for a little bit and there are some real good suggestions there Put -- DS-! Mods -In the search and check there, it is up to 2 or three pages.Good Luck and let me know how you make out-Mine is coming out real cool even with my limited knowledge and numerous mistakes.
                     Kevin
Logged
"Looky What I Done Did"
Arn C.
« Reply #5 on: December 11, 2003, 07:31:12 AM »
On the schematic where it says D5 = red led,  is that the led that is put where the "O" in Tone is?
Is it suggested that all the mods on the schematic be completed for the best sound?    geocities.com/austenfantanio/DS
Arn C.
Logged
Ansil
Guest
« Reply #6 on: December 11, 2003, 07:44:59 AM »
yeppers
  you take out teh orignal red led and replace it with your new indicator led
and put the original redled in the clipping section.
Logged
Arn C.
« Reply #7 on: December 16, 2003, 07:40:39 AM »
Wow! What great mods.  This  pedal sounds fantastic!!!!!
If you have one, I suggest trying it!  I used the schematic with both the seeing eye and the ultra mods.
Arn C.
Logged
phillip
WWW
« Reply #8 on: December 16, 2003, 11:18:02 AM »
So did you end up performing just the Seeing Eye mod, or did you go for the Ultra?
Phillip
Logged
ian87
WWW
« Reply #9 on: December 16, 2003, 01:26:52 PM »
i did the SEM according to the schem you posted, Phillip, and it sounds fantastic.
i'd like to do an Ultra, but I'm not exactly sure how to insert the extra diode and the toggle. Sad
Logged
phillip
WWW
« Reply #10 on: December 16, 2003, 01:45:26 PM »
Did you see the Ultra schematic that I posted a couple of days after the SEM?
http://axiseffects.home.att.net/misc/DS1_Ultra.gif
I'm not sure exactly how the toggle and extra LED are wired up, but that way I have drawn is probably the most simple, and it's also probably the same way he hooks it up.
Here's another new schematic that I finished a few days ago, the SD-1 5-Star Ge. mods (the other SD-1 modification schematic I have posted was my own version of the 5-star mod):
http://axiseffects.home.att.net/misc/SD1_5star.gif
I have D6 listed as a 1N34A Germanium diode, but he uses a PNP Germanium transistor wired up as a diode...won't make any difference.  I think using a diode makes a neater and cleaner modification...it just won't stand out as much as the little silver metal can of the transistor.
Phillip
Logged
Arn C.
« Reply #11 on: December 17, 2003, 07:31:05 AM »
Phillip, Below is the schematic I used for the modding.  Thank You!  I hooked it up just the way you have it on the schematic(the toggle) except that I toggled in the red led not the 1N4148 diode.   When toggled in, the led that is toggled in, I drilled out the "o" in "Tone" and placed it there.  It flashes when you play.   Great sounds!  I have no way of putting sounds on the internet, maybe once someone else gets one built they can!
Thanks again!
Arn C.
Logged
Pages: [1] Go Up Print
« previous next »
Jump to:
