Small Stone+Micro Amp
Started by petemoore, December 13, 2003, 10:14:27 AM
Ok to defeat the SS's volume drop I put a Micro Amp between the SS ckt output and the stompswitch...it works ...but...
 It seems kinda cruddy, like volume is dependant on a  power supply that's sagging? [descript bloze but] when I hit a hard note sometimes it will swell or drop in volume...
 Is there anything inherently wrong with addin a OA booster like this to the SS's power supply?
 Any ideas I might want to try before I like pull the Micro Amp bak out of there?
 Besides the other symptoms it boosts, but messes with the sound of the phazor too much IMO.
 Gonna try a different one, probably transistor booster...anyone try this adding boost to beat the volume drop on a SS? What did you find that works well for that?
Joep
I'm pretty sure there is a mod to get rid of the volume drop. If I remember well it is described in the Build reports on Tonepad.
Bye,
Joep
