Need quick help about capacitors
Started by Bill_F, December 13, 2003, 10:51:00 AM
Bill_F
Hi all,
I'm in the middle of building and have a questoin. I have some caps that I'm hoping are the right values. They are in MF and I am use to uF. The value on them says .1K could anybody tell me what that means in uF?
Thanks in advance,
Bill
smoguzbenjamin
uF stands for microFarad. So they should be the same. ;)
Bill_F
Quote from: smoguzbenjaminuF stands for microFarad. So they should be the same. ;)
That is what I was hoping. But just to make sure before I solder them in. A cap in MF rated .1k would be a .1 uF cap?
smoguzbenjamin
? 1K? Does it say "1K mF"? Cos that'd be 1 Farad. Which is improbable...
Bill_F
Quote from: smoguzbenjamin? 1K? Does it say "1K mF"? Cos that'd be 1 Farad. Which is improbable...
That's what's confusing me. It has 3 lines on it which are:
MF
250v
.1K
They are the caps that small bear sells if that helps at all.
Thanks again
smoguzbenjamin
check this page:
http://www.xtronics.com/Kits/ccode.htm
If I can read, you've got a 100 pF cap there with 10% tolerance.
But if the 'MF' means "read this in uF" then you've a 100uF cap with 10% tolerance.
Does the schematic mention 100uF cap where you're putting them?
Bill_F
Quote from: smoguzbenjamincheck this page:
Thanks again for your help,
I did look at that page too. I think the only relevant figures on this thing is .1k. Looking at SmallBears page again, I think they are the same as .1uF (I hope).
Fret Wire
Fret Wire
(Keyser Soze)
Ansil
it is a .1uf.
uf and mfd are the same thing.
let me guess radio shack caps?????
Paul Perry (Frostwave)
There are various types of ceramic used in ceramic caps, one has the code "K", might be what is going on here.
Bill_F
Quote from: Ansilit is a .1uf.
No. I got them from Smallbear.
Bill_F
smoguzbenjamin
ExpAnonColin
I have some of those too, and have used them as .1uf and they certainly SOUDNED like .1uf :)
-Colin
