Substitute for TL022
Started by Bill_F, December 22, 2003, 12:43:12 PM
Bill_F
Anyone know of a good substitute for this IC. I can't find these anywhere.
The only thing I know about them is that they are low power, so I can only assume they are used to keep current requirements down in battery-powered pedals where audio quality is not an issue (such as in LFO circuits).  What that means is that you can probably use any garden variety dual op-amp, though you can expect batteries to die a little sooner.  Obviously if you power with wall-wart, that latter aspect is moot.
Ge_Whiz
Just checking - sure you don't mean 'TL072'?
Bill_F
Thanks Mark.
Ge_Whiz,
Nope, I meant the TL022. Its the IC used in the Ibanez Flanger over at Tonepad. It uses 3 of them.
Joep
I used TL072 in mine and ik works like a charm.
You have to tweak the pot by the clock a bit to get it working. But the result will be very nice.
bye,
Joep
Fp-www.Tonepad.com
TL072 in mine also.
Sounds awesome!
Fp
www.tonepad.com : Effect PCB Layout artwork classics and originals : www.tonepad.com
Bill_F
