smoking diodes
Started by dan, January 02, 2004, 04:45:15 PM
dan
i built a milenium 1 board and tested it with the fx circuit and switch and all that. when i turned it on the diode lit up and started smoking. i don't think the led turned on but i'm not sure because i turned it off imediatly. i think this means i had the diode in backwards but i wasn't sure so i thought i'd ask.
-Dan
smoguzbenjamin
The LED started smoking? Then you pumped too much current through it! Use a higher limiting resistor ;)
dan
no, just a regular silicon diode...at least i think it's silicon. it's kind of gold looking with one black stip on one end whick i tock to be the positive end. maybe i'm confused on the diode schematics. is it like this?:
negative---|<|--------positive
[/code][/quote]
-Dan
Rick
Usually the black stripe on a diode is the cathode (negative).  I have seen some 1n914s with a confusing red stripe very close to one end. When in doubt use your meter and mark the diode with a felt pen. Btw what sort of power supply are you using. 9v I hope , just curious as I haven't smoked a diode as yet, but i'm willing to try it if it gives a good buzz!
dan
ok, i should of done that, thanks. that's the problem
-Dan
bwanasonic
Quote from: Rickjust curious as I haven't smoked a diode as yet, but i'm willing to try it if it gives a good buzz!
Don't bogart that diode my friend...
Kerry M
