Switchcraft Closed Tip 12A Jacks...
Started by Hal, January 11, 2004, 09:05:15 PM
Hal
can these be used instead of stereo for battery switching?  It looks like it...unless I'm missing something.
ExpAnonColin
Well, the way that the stereo jack battery switching works is that the -9v is connected to the shaft of the mono jack, and then to ground, only when a mono plug is put in, which basically connects the - side of the 9v battery to the circuit.  The switched ones wouldn't work so well-you don't want to have the -9v connected to anything but ground, not the tip.
-Colin
Peter Snowberg
No they can't. The switch in a #12A is closed when nothing is plugged in and it switches to the audio conductor too. It's exactly opposite on both counts.
Your other option would be the #13 which has an isolated switch.
Take care,
-Peter
Eschew paradigm obfuscation
