CA3080 Replacement
Started by MRTelec, January 23, 2004, 08:16:06 PM
MRTelec
Hi,
I'm building a compressor and my supplier is out of CA3080s.  What's a suitable replacement for this part?  I searched the archives but couldn't find an answer.
Thanks.
puretube
uncle boko
Did you mean CA3094 or CA3080??
better to be in bad taste than to taste bad
MRTelec
I meant CA3080.  Sorry.   :P
hank reynolds 3rd
try a lm13700...
its more or less  2 3080's in one chip
sam
Although you can use an LM13600 r 13700 as a suitable replacement OTA for design purposes, neither of these willsimply sub for a 3080.
Do note that the LM3080 is the same thing as a CA3080, just a different manufacturer.  Most supply houses will be astute enough to recognize that there is no difference, but it wouldn't be the first time I've seen someone look up stock on a part using the prefix as a core part of the search string to the complete neglect of equivalents bearing other prefixes.
I'm assuming there is an NTE/ECG replacement but I don't know the number.
Paul Perry (Frostwave)
MRTelec
Thanks for the help.  I was hoping to order it from Digi-Key along with my caps, but they don't have anything.  I'll put together an order for Small Bear.
