|AMPAGE| |GEOFEX| |AMZ|
May 22, 2013, 01:14:28 AM
891262 Posts in 97592 Topics by 28684 Members
Latest Member: slime
Home Help Login Register
DIYstompboxes.com  |  Projects  |  Beginner Project  |  death by audio- Total sonic annihilation diy tutorial 0 Members and 1 Guest are viewing this topic. « previous next »
Pages: [1] Go Down Print
Author Topic: death by audio- Total sonic annihilation diy tutorial  (Read 5414 times)
Ansil
Guest
« on: January 26, 2004, 03:48:24 AM »
http://www.geocities.com/austenfantanio/weedingout/Sonicdeathtutorial.htm
i thought this might be a good beginners tutorial
not down just moved i got hacked earlier in the year
Logged
smoguzbenjamin
Ben Allen
« Reply #1 on: January 26, 2004, 09:31:21 AM »
May I add that this is a feedbacker. It's not your regular effect and it has the potential to make so pretty wierd an cool noises, aswell as screaming distortion feedback! Cheesy
Logged
Snoo
WWW
« Reply #2 on: February 06, 2004, 07:10:07 AM »
I was looking at a review of this pedal over at www.harshnoise.com the other day.
Can somebody point me to a supplier of that stomp switch?
Also, would that be a Log of Lin pot. I'm assuming Lin..
Thanx.
Logged
Chris R
« Reply #3 on: February 06, 2004, 07:49:25 AM »
the switch is a
Taiwanese "Blue" - 3PDT--True-bypass
you should be able to get everything from
http://www.smallbearelec.com/
Logged
Snoo
WWW
« Reply #4 on: February 06, 2004, 08:00:16 AM »
Quote from: Chris R
the switch is a
Thankyou for that. I'm in the UK though.
I guess I'll have to try to track one down.
Logged
Snoo
WWW
« Reply #5 on: February 06, 2004, 08:06:14 AM »
Found One!
For the benefit of anyone else in the UK.
http://www.wah-wah.co.uk/price.html
Logged
smoguzbenjamin
Ben Allen
« Reply #6 on: February 06, 2004, 08:11:31 AM »
Snoo, smallbear also exports orders to non-US countries. I think the weight limit for that is 1 lbs though :roll:
Logged
bobbletrox
« Reply #7 on: February 18, 2004, 03:09:57 AM »
Hey Ansil!  The scan pic shows a 100k log, but your text says you used a 500k...which one did you end up using?
Logged
smoguzbenjamin
Ben Allen
« Reply #8 on: February 18, 2004, 10:17:00 AM »
I doubt that it would make much difference Wink
Logged
blabj
WWW
« Reply #9 on: March 08, 2004, 05:08:56 AM »
snoo,
this is probably extremely late now but hey, for future reference Wink the way ansil had the switch wired up on the pic shows how you could wire it up using just a dpdt and not using an L.E.D, although an L.E.D is very desireable  Cool
MEH!
callum
Logged
doug deeper
« Reply #10 on: March 09, 2004, 01:30:24 PM »
this can be made with an spst also...and its much cheaper....(no led though)
doug deeper
mid-fi electronics
Logged
Robzilla
« Reply #11 on: May 18, 2004, 09:35:45 AM »
It's down?
Sad
Logged
Smiley
Ansil
Guest
« Reply #12 on: May 18, 2004, 12:40:08 PM »
Quote from: Robzilla
It's down?
Sad
nope its not down just moved
Logged
remmelt
Remmelt P.
WWW
« Reply #13 on: July 04, 2004, 03:33:16 PM »
is this for real?
the guy wants 150USD for it!
i came across this pedal a couple of months ago on the net and thought it was pretty funky. if this is really all there is to it, i'm building it for sure.
Logged
Marcos - Munky
Marcos Paulo Baliscei - Brazil
« Reply #14 on: July 04, 2004, 04:37:05 PM »
Yes, just build it. To tell the truth, I didn't checked Ansil's schematic, but in this link (http://www.geocities.com/munkydiy/loop.jpg) there is the same version that I built. Use a 500K pot.
Logged
Mike Nichting
« Reply #15 on: July 11, 2004, 01:57:14 PM »
if anyone wants a schematic to see how to wire up the switches go to www.banzaieffects.com and then go to "Parts shop" then to "switches" and then you will see a link that says "How to wire a switch" click that and then you will have a page that shows about 4-6 ways to wire different switches.
All the best.
Mike N
NUKLHED
Logged
"It's not pollution thats hurting the earth, it's the impurities in the water and air that are doing it".
Quoted from a Vice President Al Gore speech
Pages: [1] Go Up Print
« previous next »
Jump to:
