tonepads tubescreamer...
Started by wulla, February 08, 2004, 05:49:26 AM
wulla
Sorry for the dumb question but...
In the schem for the tubescreamer from tonepad I cannot see a footswitch. There is no footswitch in the parts list. Can anyone help me out here? thanx.
Sic
Here is a TS build from GuitarGadjets...
TS
Hope this helps, might not but its worth a shot
Travis
The switch is in the schem.  It is represented by the angled lines ending with arrows that come off of the input and output jacks.
It isn't shown in the layout, but the in and out pads are labeled.
http://www.tonepad.com/getFile.asp?id=1
edit: Sic is right , though.  GGG is generally a bit more beginner friendly.
http://www.generalguitargadgets.com/v2/index.php?option=displaypage&Itemid=118&op=page&SubMenu=
wulla
jimbob
I was in the same boat when i 1st started and although tonepad doesnt ussually show the switch wirings its a great site to come back to after learning from GGG site. GGG friendlier to beginners, i think.
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
Fp-www.Tonepad.com
I get quite a few questions on the 'other' offboard wiring, so I made this project available:
http://www.tonepad.com/project.asp?id=35
I hope it helps!
Fp
www.tonepad.com : Effect PCB Layout artwork classics and originals : www.tonepad.com
after getting a couple TBypasses wired, it becomes second nature.
 I find it easier to build ckt's using 'bare bones' schematics with no jacks or bypass switches shown.
 I've passed over a building a few ckts because millenium bypass is 'mixed' in and I don't use them and find it confusing to separate the bare circuit from the MB portion.
 Most schematics are easy to read, but some add so much 'wierd' stuff [those folded and convoluted switch wirings that read like a complex maze]...
 I still haven't figured out how the PS wiring works on the Bear Face...don't need the indicator or the FF [ I have one]...the switch wiring couldn't be more confusing [fortunately I know to look for 'standard' places for inputs.
 But, How DOES one power an OA with a PNP FF [pos Gnd.] using the same power rails?    ...or is that an NPN FF?
