the overdrivepro
Started by youngi, February 23, 2004, 10:29:28 AM
youngi
hi,
there's a sample with very low overdrive settings(that's what i like)
the problem is that there's still noise in the background, how do i get rid of it?  [u'll notice it when i change the pickup which then higher the volume and the noise gets louder]
in the sample i began with the humbucker which is lower from the strings than the other two pickups, then switch to the single pickup.
i found that the last one also makes the bass higher.
please help me with that noiiiiiiisssssssseeeeeee.
http://membres.lycos.fr/youngilaboungi/odrivepro.mp3
smoguzbenjamin
It could be your pickups, my single-coils pick up a lot of hiss unless I'm using two (the middle one's polarity is reversed) in a humbucker configuration. If there's no hiss, or less hiss, when you use two single-coils or one humbucker then it's your pickups.
I couldn't reach your site, but I didn't understand the erro messages though :D
youngi
ok, i fixed it,
click on the link at top of the page.
look, i'm sure it's not the pickups(very sure),  i know it's from the pedal.
do i have to add resistors or something???
