Ring Stinger.
Started by sirkut, March 02, 2004, 09:42:14 AM
sirkut
Just wanted to give you guys a heads up. With the tradition of sharing, I got a bro in ann arbor that has a ring stinger. He's going to be giving me some hi res photos of both top and bottom of the pcb of his ring stinger, and will give me a detailed list of the parts where legible. I was wondering what else would I need to get him to do other than taking closeup photos?  I dont know about you but I really want to get a clone of this pedal.
psst
Quote from: sirkutI dont know about you but I really want to get a clone of this pedal.
Dude, I DO want a clone too!!!  :D
Keep us updated!!!  :wink:
gurutzeta
Agree with psst!!!
Please keep us updated
axr
also some pics of the pots and wires could help
Joep
Let me know if you need help reverse engineering. That;s my favourite part!
Bye,
Joep
Marcos - Munky
I like to clone it too. Pics of the board, copper, wires, pots and maybe some voltages will help.
sirkut
Great that there is some interest in this. I'll be getting the pics sometime in the next few days. The only problem is I'll have to talk to him about taking voltages, that'll be the hardest part considering he is in a different state as me. I can't wait myself either!
Sometimes the wires are hard to sort out from a photo...knowing which one goes to the middle lug, or more detailed accompanying wiring text...
 Hopefully the pot values are marked.
ExpAnonColin
You know, if you really look at the device it wouldn't be that hard to make a workalike.
It's an old-design pattern, with 2 transformers and the diode "ring".  In order to get the guitar up there, I'm sure there's some sort of an input boost, probably an op amp.  The VCO wouldn't be that difficult, especially if you could live without the sine and sawtooth waveforms.  An LFO would be as simple as a schmidt trigger/integrator pattern driving an LED to an LDR to the frequency pot.  The timbre control is just a tone knob.
-Colin
swt
i'm also in for that schem!!. Let me know if i can help.
psst
Quote from: JoepLet me know if you need help reverse engineering. That;s my favourite part!
Listen to Joep, Sirkut, his works are VERY nice.
psst
BTW, Sikut, I would welcome a scanning of the manual, too.   :wink:
sirkut
Actually Joep's response gave me a warm feeling inside!
From the title it sounds like a Ring Mod Fuzz. ?
 Well whatever it is it's a cool title, and I too would like to take a look at this one!!!
 Thanks, and have a great 'Retro'!!!
gurutzeta
Quote from: petemooreFrom the title it sounds like a Ring Mod Fuzz. ?
you can listen to it here http://www.lovetone.com/ringstinger.html
Gripp
Count me in as very interested!
Now if I only could get my lazy *** to order some VTL5c3's so I can get get going on the mcmeat...
Best!
/Pelle Garpebring
toneless
I tried to build a classic ring modulators once but with no luck... :(
I really hope this schematic will be online.
Please don't forget to learn anything you can about the transformers!!!
sirkut
Well, due to certain circumstances, I won't be able to receive those photos sooner than I thought. On the other hand, I'll be taking a trip to Michigan to do a few shows, while I'm there, I'll be personally be taking a load of pictures and measurements of the ring stinger. That will be form the 15th to the 18th. Expect sometime after that some results! Just wanted to keep you posted.
Paul Perry (Frostwave)
For a ring modulator using a transformer & "diode ring" approach, I believe it matters a GREAT DEAL how well the diodes are matched (depending wha\t you wnat to do with ti musically, it may be that perfect matching is not the best, of course).
brett
You also need to very accurately balance the two "halves" of the transformer output (not easy), otherwise you get heaps of modulation signal through.  Foir this and similar reasons I gave up on a transformer-based modulators and designed a switched "balanced" modulator - the Modulatron, mentioned in earlier threads.
Brett Robinson
