Author Topic: Colorsound Dipthonizer  (Read 10460 times)
Travis
« on: March 06, 2004, 03:47:49 AM »
Does anyone have the circuit for the Colorsound Dipthonizer?  It sounds pretty cool, kind of in the vowelly vein of the Ludwig Phase II we've been hearing so much about.
If anyone knows the basic structure, or has heard one, that info would also be appreciated.
Paul Perry (Frostwave)
« Reply #1 on: March 06, 2004, 05:47:57 AM »
Diphonizers consist normally of two paralled filters. http://physics.indiana.edu/~p105_f02/vowel_recognition.gif
shows the frequencies associated with the 2 filters, for various vowel sounds. And shows that to get all (or most) with a single control, would require a way to move around the space shownb there.
One way might be to have a single pot (YEA!) generating a voltage, which is transformed into two separate voltages (one linear, the other U or V shaped) which then control two VCFs. That way with one sweep, you can cover an interesting range.
I think this might be covered in the Geofex Wah history??
NB I know nothing specific about the Colorsound unit.
Travis
« Reply #2 on: March 06, 2004, 06:21:05 AM »
He certainly does spend a bit of time on the vocal quality of wahs, and a bit more time on how to make them more vocal and vowel-like.
I'm more interested in seeing how the Kent/Schaller Yoy-Yoy type dual inductor or even a parallel twin-t would work in an EF.  Of course, it also never hurts to see how people overcome certain inherent design deficiencies.
Having never even heard one of these, I'm also interested in hearing the vowel frequency switching design; whether electrical (RG) or mechanical and its counterparts (Yoy-Yoy or equivalent parallel setup).
« Reply #3 on: March 08, 2004, 11:16:23 AM »
Now THERE is something that needs resurrection!
The Schaller/Kent Yoy-Yoy option on their wah is one of the niftiest sounds I've ever had the pleasure of owning (and one that I deeply regret selling).  If good wahs sound "puke-ey", a decent Yoy sounds "pout-ey" (as in a 9 year-old taking a temper tantrum).
Confirmation of the existing posted schematic (courtesy of Stellan Lehrberg), and inductorless attempts at mimicking it or extending it (for example envelope-controlled versions) will be deeply appreciated.
There comes a point where sweeping a bandpass filter just doesn't seem like enough.
gez
« Reply #4 on: March 08, 2004, 11:47:55 AM »
Quote from: Travis
After receiving some excellent advice from Tim E last year I did some (still am doing some) messing around with twin Ts.
I paralleled a couple of filters and controlled them with an envelope follower.  Although definitely a wah, it sounded more like a phaser at times.  It had a throaty sound to it (I nicknamed it 'Sweep Throat') which you don't get with a single filter!
I'd do it very differently now, but the idea is worth toying with - you can get some interesting effects.
Tim Escobedo
« Reply #5 on: March 08, 2004, 01:51:04 PM »
Playing with the two parallel filter idea, I found that simple Twin T/bridged T circuits leave something to be desired. Mostly because, to my ears, they behave more like resonant lowpass filters than bandpass filters. Changing to a Multiple Feed Back (MFB) bandpass filter yielded nicer results, as the output seems to be a "better" bandpass response.
The downside to the MFB filter is that gain is greatly reduced as the filter is swept up, which leads to some hack-ish things in order to compensate. Ultimately, I think a much better way to do this would be to use at least two parallel state variable filters in bandpass mode.
I would be very interested in how Colorsound and EHX did this.
Pedro Freitas
« Reply #6 on: March 08, 2004, 04:28:08 PM »
I messed around with the bass balls circuit with pleasing results.
Just replaced the transistor controlling the filters with a pot and
got a very vocal wah effect.
Varying this resistance along with only one of the trimmers
at the same time produced several different vowels.
I used a dual pot for this.
Pedro
« Reply #7 on: March 08, 2004, 05:10:21 PM »
As part of the ludwig follow up, I have a design for a dual filter that does some of this, I think.
I didn't like the twin t or LC filters I messed with. The one that seems to work OK is the state variable.
I have a design in the proving stages with two filters. Each filter is one LM13700 dual OTA, and the nice thing is that you just hook the control pins in parallel and you can think of it as one filter chip. You get either linear or exponential response depending on how you drive the control pins, and it will go from subaudio to ultrasonic in a single filter if you really want to, as well as Q's from about 1 up to 20 or so.
A single LM13700 makes a pretty good wah by itself, as you can include a clipping feedback on the filter itself.
I'll put the schemo up as soon as I get a chance.
Quick IQ Test: If anyone in a governmental position suspected that YOU had top-secret information on YOUR computer, how many minutes would you remain outside a jail cell?
Mr_Destruct
Re: Colorsound Dipthonizer
« Reply #8 on: September 17, 2011, 08:54:46 PM »
Reviving an old thread :) Found the Colorsound Dipthonizer schematic incredibly difficult to decipher, so here it is - updated with legible values and mods:
Special thanks to Dino for uploading this, really appreciate it man! :icon_biggrin:
Still unverified, but have compared it to plenty of boards and layouts so it should be good to go. Gonna start breadboarding it within the next couple of days... If anyone spots a mistake or three, please let me know!
->Erik
« Last Edit: September 17, 2011, 09:08:52 PM by Mr_Destruct »
toneman
« Reply #9 on: September 17, 2011, 10:24:06 PM »
did U miss this thread?
http://www.....org/viewtopic.php?f=19&t=2007
 8)
pinkjimiphoton
  • Poster2
  • Total likes: 319
  • High priest, Cult of Germanium, and Dudeist Monk
    • odds are i'm probably banned  here...
« Reply #10 on: September 17, 2011, 10:53:05 PM »
toneman, can you fix the link please? looks like the forum software broke it.
digi2t:
"Fuzz, distortion, and wah, are plenty abound. Mutron Flanger, not so much.  8)"
#FuzzyGoodness
Mr_Destruct
« Reply #11 on: September 17, 2011, 11:29:44 PM »
Toneman: Didn't miss it no, that was me 8) Thanks for all your work man, amazing stuff! All I did was update the values and mods against the schematic... I'm nobody really. The original schem was giving me a headache :icon_confused:
Jimi: Just add - /viewtopic.php?f=19&t=2007&start=160 - after the "other forum"-address :)
->Erik
digi2t
  • Poster2
  • Total likes: 731
  • "Digital? Any idiot can count to 1!" - Bob Widlar
« Reply #12 on: September 18, 2011, 08:28:39 AM »
No problem Erik. FYI, just open a free account on Photobucket (or any picture server FTM), and upload your pics there. Then stick the link from there into your post.
Piece 'o' pie  :icon_razz:
Cheers,
Dino
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
"Turn down the amp, strum harder."  - PRR
Mr_Destruct
« Reply #13 on: September 18, 2011, 09:22:19 AM »
Cheers Dino! Will do for the next stuff I post. Starting the breadboarding later today 8)
toneman
« Reply #14 on: September 18, 2011, 10:14:39 AM »
the dipthonizer and vocalizer both use MFBF (MultipleFeedBackFilters).
tedious to tune cause U are supposed to keep the cap values the same.
my 2 dipthonizer builds are working, but don't sound right yet.
I am starting to tweek the cap values
notice the cap values of the EH Talking filter.....slightly different......
shooting for something inbetween.....
thinking about adding a rotary switch similar to the MeatBall.....
The MeatBall uses MFBF also......
will post more info if/when I succeed    :-\
more links again---
http://www.diystompboxes.com/smfforum/index.php?topic=92202.0
http://www.diystompboxes.com/smfforum/index.php?topic=91774.0
Hmmm, direct links to the "other forum" seem to be blocked....
copy link, paste link, remove "*", then press return.
U will have to be logged in to view images.....
this is where ALL the info is.......
http://www.free*stomp*boxes.org*/viewtopic.php?f=19&t=2007
http://www.free*stomp*boxes.org*/viewtopic.php?f=19&t=13235
 8)
Ronan
« Reply #15 on: September 19, 2011, 05:32:31 AM »
I am such a loser, after playing around with Bassballs on breadboard, and having good results like Pedro in post 6, then wanting to try more circuits so ordered 5 more breadboards from ebay, wondering whether to do a Colorsound Vocalizer, or Dipthonizer, or ehx Q-Tron, or ehx Talking Pedal, then out of the blue I bought an ehx talking machine from ebay last night. Damn! What was I thinking...i dunno i couldn't help myself...
Interesting to see all the filter heavyweights posting on this same subject in 2004. What those guys must know now, and they still share, I for one really appreciate it. The vowell sound pedals just fascinate me no end, a wah pedal has been part of my sound forever, I always wanted a voice box, I saw one in 1982 for sale but couldn't afford it, money was scarce back then.
« Reply #16 on: September 19, 2011, 09:01:33 AM »
One of the experiments I started thinking about on the busride this morning was using an expression pedal to foot-sweep one of the filter sections in the Bassballs.  The transistor that is used like a voltage-controlled resistor to ground to sweep the centre-frequency of each bandpass filter section is in parallel with a 47k resistor to set maximum resistance.  It is a trivial matter to set the trimpot for one of the filter sections so that it doesn't sweep in response to envelope, wire up a jack for an externally controlled variable resistance, and either place that resistance in parallel with the 47k resistor, or replace it, using a jack that will switch the 47k out.  This would let you have one section that sweeps upward in response to picking strength, while you sweep the other one down in the fashion you want.
As is, appropriate trimpot adjustment on a stock unit can get you some vowel-like sounds.  being able to control both the direction and differential sweep if the two filters should be able to get one close to formant movement.  And of course, since you still have the option of using envelope control over the transistor in tandem with a foot-controlled resistance for that filter section, there are a lot of possibilities.
« Last Edit: September 19, 2011, 09:03:16 AM by Mark Hammer »
digi2t
  • Poster2
  • Total likes: 731
« Reply #17 on: September 19, 2011, 09:11:07 AM »
I've been tempted to try my hand at the ehx Talking Pedal, using either LDR's to fake the "unobtainium" pots, as per ToneGod's Rock N' Control. There is also a thread somewhere here outlining replacing the pots with trannies, IC's, and trimmers (complete schematic is there). Guess that's the "sucker-for-punishment" in me
BUT... is it really worth it? I've listened to some clips, including pot work arounds, and it doesn't really seem to be THAT impressive. I think that either the Dipthonizer, or Vocalizer (to a lesser degree... if we can get it working!) would be more "interesting"? I must admit though, I've been spoiled of late. The Humanizer on my GT-PRO is in a league of it's own. But, I digress.
Honestly, keeping to DIY territory, I say the Mold Spore wah would be a much better build if one is looking for trash-mouthiness. Less of a one trick pony. This video reall got my attention;
If there is interest, I don't mind tackling a vero of the Mold Spore. Something that fits into a Crybaby shell.
Dead End FX
toneman
« Reply #18 on: September 19, 2011, 08:41:54 PM »
The MeatBall  (MeatSphere, Meat-O-Lation, McMeat)  is a great EnvFol pedal  :icon_exclaim:
I removed the clone layout I had at Photobucket because it had errors.
Today I uploaded a pic of my progress on the Dipth-O-lation to my PhotoBucket album.
It shows my custom preamp, format mixer and clip indicator.
Still needs tuning to get "that sound".
Not there yet.
Oh, found some resistor errors in that recently posted schematic.
afn
 8)
