Smash Drive Parts
Started by Pho, April 01, 2004, 09:22:13 PM
aron
Use a socket for the input cap so you can change the cap later depending on your guitar.
From the beginner project (which you should check out):
See how I used an IC DIP 8 socket to create a smaller 3 pin socket. In your case, you only need 2 pins.
Solder the 2 pin socket into your board and insert the capacitor into the socket. Try different capacitors for differnet tones.
Pho
Ah right thanks, I'll go and read those (I only read the first couple, with the one with the schematic parts list).
