Author Topic: Small Pignose Amp Schematic?  (Read 10360 times)
Arn C.
« on: April 22, 2004, 08:43:37 AM »
Howdy All,
    I was given a junk Pignose, the little portable, with the "pignose" on the front model 7-100-(R)  It has roughly a 5" speaker.
    One of the two transformers on the circuit board was not soldered onto the board, and I do not know which way to orientate it.  It is the larger transformer.  (both sides of this transformer has 3 taps)
     Anyone have a schematic or knows which way the transformer goes into the board?  The larger transformer also has a red stripe on the top on one side of it, if that helps.
     Also I just measured each side(ohms)  The red stripe side has 1.9 ohms outer tap to outer tap, the other side is 5.1 ohms outer tap to outer tap.
Arn C.
« Reply #1 on: April 22, 2004, 09:49:12 AM »
I don't have it on me at the moment, but I believe it was posted around since I know I snagged it somewhere on-line.
B Tremblay
« Reply #2 on: April 22, 2004, 10:22:22 AM »
B Tremblay
runoffgroove.com
Arn C.
« Reply #3 on: April 22, 2004, 10:45:52 AM »
Thank you so much!  Exactly what the doctor ordered!
Peace!
Arn C.
Marcos - Munky
« Reply #4 on: April 22, 2004, 11:10:47 AM »
Check your e-mail for the schematic.
Arn C.
« Reply #5 on: April 22, 2004, 12:47:46 PM »
Thanks Marcos!!!  There was one wire where I didn't know where it went!
Thanks again!!!
Peace!
Arn C.
Tubebass
« Reply #6 on: April 22, 2004, 02:33:35 PM »
Could I get a copy of that too, please?
More dynamics????? I'm playing as loud as I can!
D Wagner
« Reply #7 on: April 22, 2004, 04:32:08 PM »
Is there a chance that I could get that schematic, too?  I have some transformers for that type of amp that need a good home.
Thanks in advance!
Derek
datilderek@excite.com
djmartins2
« Reply #8 on: April 22, 2004, 06:29:45 PM »
Hi,
Could y'all also send a copy to
djmartins2 @ comcast.net
I searched the web and couldn't find a copy anywhere!
thanks,
DJ
Marcos - Munky
« Reply #9 on: April 22, 2004, 10:06:36 PM »
Schematic sent. Hey Tubebass, I need your e-mail address.
Gilles C
« Reply #10 on: April 22, 2004, 10:39:25 PM »
Ahhh, I hate to say this... but I would like a copy too.  :oops:
My address is good if you click on the author's name on the left.
Thanks,
Gilles
Gilles C
Heu, I meant on the "Private Message" botton...
« Reply #11 on: April 22, 2004, 10:41:17 PM »
thanks again
javacody
  • Poster2
  • Total likes: 0
  • Blah Blah Woof Woof --Jimi Hendrix
    • javacody
« Reply #12 on: April 22, 2004, 11:20:59 PM »
Marcos, could I get a copy too?
c.fyler at mchsi.com
Marcos - Munky
« Reply #13 on: April 23, 2004, 11:34:51 AM »
Schematic sent.
Torchy
« Reply #14 on: April 23, 2004, 06:03:01 PM »
Marcos, thanks for the schemo guy :)
Gilles C
« Reply #15 on: April 24, 2004, 10:45:50 AM »
While checking the Pignose schematic Marcos sent me, I remembered this excellent one.
http://www.redcircuits.com/Page52.htm
I wanted to make a pcb layout for it, but ... it's still not done.I would be curious to compare it to the sound of a Pignose. I like discrete  :lol:
Gilles
toneman
« Reply #16 on: April 24, 2004, 11:12:43 AM »
nice link.
thanx Gilles!
tone
casperssoul
Re: Small Pignose Amp Schematic?
« Reply #17 on: June 27, 2014, 04:11:56 PM »
I need help with a vintage pignose 7-100 r. I have worked with it enough to get sound out of it. When I received it the batteries has destroyed the majority of the existing wiring for the input & power switch/vol knob. The battery pack has been removed and would love to just leave it as a plug in amp as I do not care about the battery power nor do I want to corrode the repaired solder joints. I have photos i can supply.. I have the schematic as well, although, it confuses me, I have done guitar restores in the past
casperssoul
« Reply #18 on: June 27, 2014, 04:39:54 PM »
Red wire i believe was originally the battery positve.
http://s92.photobucket.com/user/evon_ishot/media/WP_20140626_0042014062716143220140627161622.jpg.html
Blue wire shows as a ground by way of volt meter.
http://s92.photobucket.com/user/evon_ishot/media/WP_20140626_0042014062716143220140627161726.jpg.html
Black wire shows as a ground by way of volt meter. Which i believe to be oringally battery ground..
http://s92.photobucket.com/user/evon_ishot/media/WP_20140626_0052014062716182020140627161948.jpg.html
This is my power switch/input side as i recieved it..
http://s92.photobucket.com/user/evon_ishot/media/WP_20140626_006.jpg.html
Where do these wires go!? If I use black to the top of input that is empty but has old solder on it in photo and twist the blue and red together I get sound.. although it is very low and very fuzzy.. ???
