Small Pignose Amp Schematic?
Started by Arn C., April 22, 2004, 08:43:37 AM
Arn C.
Howdy All,
   I was given a junk Pignose, the little portable, with the "pignose" on the front model 7-100-(R)  It has roughly a 5" speaker.
   One of the two transformers on the circuit board was not soldered onto the board, and I do not know which way to orientate it.  It is the larger transformer.  (both sides of this transformer has 3 taps)
    Anyone have a schematic or knows which way the transformer goes into the board?  The larger transformer also has a red stripe on the top on one side of it, if that helps.
    Also I just measured each side(ohms)  The red stripe side has 1.9 ohms outer tap to outer tap, the other side is 5.1 ohms outer tap to outer tap.
Arn C.
I don't have it on me at the moment, but I believe it was posted around since I know I snagged it somewhere on-line.
B Tremblay
B Tremblay
runoffgroove.com
Arn C.
Thank you so much!  Exactly what the doctor ordered!
Peace!
Arn C.
Marcos - Munky
Check your e-mail for the schematic.
Arn C.
Thanks Marcos!!!  There was one wire where I didn't know where it went!
Thanks again!!!
Peace!
Arn C.
Tubebass
Could I get a copy of that too, please?
More dynamics????? I'm playing as loud as I can!
D Wagner
Is there a chance that I could get that schematic, too?  I have some transformers for that type of amp that need a good home.
Thanks in advance!
Derek
datilderek@excite.com
djmartins2
Could y'all also send a copy to
djmartins2 @ comcast.net
I searched the web and couldn't find a copy anywhere!
thanks,
DJ
Marcos - Munky
Schematic sent. Hey Tubebass, I need your e-mail address.
Gilles C
Ahhh, I hate to say this... but I would like a copy too.  :oops:
My address is good if you click on the author's name on the left.
Thanks,
Gilles
Gilles C
javacody
Marcos, could I get a copy too?
c.fyler at mchsi.com
Marcos - Munky
Torchy
Marcos, thanks for the schemo guy :)
Gilles C
While checking the Pignose schematic Marcos sent me, I remembered this excellent one.
http://www.redcircuits.com/Page52.htm
I wanted to make a pcb layout for it, but ... it's still not done.I would be curious to compare it to the sound of a Pignose. I like discrete  :lol:
Gilles
toneman
TONE to the BONE says:  If youTHINK you got a GOOD deal:  you DID!
casperssoul
I need help with a vintage pignose 7-100 r. I have worked with it enough to get sound out of it. When I received it the batteries has destroyed the majority of the existing wiring for the input & power switch/vol knob. The battery pack has been removed and would love to just leave it as a plug in amp as I do not care about the battery power nor do I want to corrode the repaired solder joints. I have photos i can supply.. I have the schematic as well, although, it confuses me, I have done guitar restores in the past
casperssoul
Red wire i believe was originally the battery positve.
http://s92.photobucket.com/user/evon_ishot/media/WP_20140626_0042014062716143220140627161622.jpg.html
Blue wire shows as a ground by way of volt meter.
http://s92.photobucket.com/user/evon_ishot/media/WP_20140626_0042014062716143220140627161726.jpg.html
Black wire shows as a ground by way of volt meter. Which i believe to be oringally battery ground..
http://s92.photobucket.com/user/evon_ishot/media/WP_20140626_0052014062716182020140627161948.jpg.html
This is my power switch/input side as i recieved it..
http://s92.photobucket.com/user/evon_ishot/media/WP_20140626_006.jpg.html
Where do these wires go!? If I use black to the top of input that is empty but has old solder on it in photo and twist the blue and red together I get sound.. although it is very low and very fuzzy.. ???
