Tonepad's BMP pcb question
Started by PB Wilson, April 27, 2004, 04:01:42 PM
PB Wilson
I'm planning on building a variation on the Big Muff Pi and due to the number of parts, I'm not too keen on building it on perfboard.  :shock:
I was looking at different pcb layouts on the web and had a question about Tonepad's layout. There appear to be two +9v pads on the pcb. Does it matter which one I use?
And compare. with PCB..Get the DMM on beep mode, Black to the 9V+ Pad, where battery connects, and see if you get continuity to all points  on the board that call for it for 9V+.
Gringo
It doesn't matter which one you use, just go with the one that better suits your box layout.
Cut it large, and smash it into place with a hammer.
http://gringo.webhop.net
PB Wilson
