Author Topic: Transistor Equivalent  (Read 29063 times)
Davide
« on: May 06, 2004, 01:57:08 PM »
Hi ! i've seen in many schematics it's often used the 2N5088 NPN transistor.
Here it's terrible hard to find.. i've heard BC383, BC549 , BC550 etc can be considered good workalike.. is it true ? Has someone tried'em ?
Gringo
« Reply #1 on: May 06, 2004, 02:16:11 PM »
Yeah, you can sub 5088's with bc549C's all day.
Cut it large, and smash it into place with a hammer.
http://gringo.webhop.net
Davide
« Reply #2 on: May 06, 2004, 04:03:30 PM »
Gracias Gringo :) !
Davide
« Reply #3 on: May 08, 2004, 07:59:57 PM »
Another good 2N5088 equivalent.. ?
Gringo
« Reply #4 on: May 08, 2004, 08:16:49 PM »
You can try any npn with hfe over 500. BC547/548/549/550 from the C series shoud do the trick, but only the 550 has the same noise figure of the 5088. Another sub is the BC169, you can even try a bc108/109C. Other than that, you can go the nte way, but those parts are expensive and with more *random* specs. I´m not familiar with 2SBxxxx transistors, but you should find some equivalent to the ´88.
Saluti dall'Argentina ;)
Edit: The BC237/238/239 series is also usable.
From the faq: "From R.G.Keen:
2N5089 will work in most instances. Also useful are 2N5210, 2N4401, BC549."
Davide
« Reply #5 on: May 09, 2004, 06:29:25 AM »
I asked it because i order transistors in a website... all transistors are in 1-5 pieces per packet... but BC549 minimum number is.. 2000 :shock: ...
i'm not going to spend 50€ to buy a Kg of transistors  :D  !
Thank you again !!!
Saluti dall'Italia  :wink:
Davide
« Reply #6 on: May 12, 2004, 06:14:00 PM »
Another equivalents question :)   :
i'm going to build Dod Fx-86...  there's a  K30A transistor (a mosfet i think..) that i'm not able to find... some alternatives :) ?
Thank you !!
Gringo
« Reply #7 on: May 12, 2004, 09:20:34 PM »
If it is a 2sk30, it's a fet, and you can sub it with almost any common fet. Check out the faq, but a few that come to mind are mpf102, bf245a, 2n5457/58, j201, etc.
Davide
« Reply #8 on: May 13, 2004, 05:15:15 AM »
R.G. wrote : The K30A is obviously a 2SK30A JFET
 :P
Thank you Again !
Zero the hero
« Reply #10 on: May 14, 2004, 05:04:39 AM »
BC264 works well as 2SK30A substitute. Check for different pin-out.
I used this one in many projects, with no problems.
Un'altro italiano in questo forum?
Davide
« Reply #11 on: May 14, 2004, 08:06:19 AM »
Thank you :) I'll follow the suggestion ;)
(ebbene sì :P)
Davide
« Reply #12 on: May 14, 2004, 08:13:47 AM »
mmm some problems findin' BC264 .. is BF245C a good equivalent ?
