Ring Frobnicator Problem
Started by John Egerton, June 06, 2004, 11:18:16 AM
John Egerton
Hey guys..
I built the ring frobnicator exactly as stated on the geofex site however i'm having a problem...
The 2 led's are lit dimly all the time and all i get from the pedal is a clean sound at a lower volume that a bypassed sound...
its a little weird...
any help would be great...
John
Save a cow... Eat a Vegetarian.........
brett
Hi.
1. Try using a partly flat battery, or
2. Use two resistors to form a voltage divider (e.g. 10k+1k) across a 9V battery, then tap the centre for a lower voltage power supply (a bit over 8V)
I suspect that the above are due to Hohn Hollis' neat idea of using 2 LEDs for the bias in the LFO.  Maybe some LEDS don't have enough voltage drop?  But I'm only guessing.
cheers
Brett Robinson
John Egerton
so have a lot of people had the same problems?
Its a very strange...
Thanks for the help..
John
jrc4558
Make shure you use EXACTLY same LEDs for all three of them! Otherwise the bias is upset. This is exactly what I can into with anither John's cirquit - EZVibe...
