Tech21 Sansamp Bass Driver DI schematic
Started by ejbasses, June 08, 2004, 03:24:30 PM
ejbasses
Ive seen how ell the GT2 is doing her.
Does any one have aschematic of this baby??? PLEASE!!
Four Strings To Rule Them All And In The Darkness Bind Them
zener
sensya na pero... madaling araw pa/na ah :wink:  tulog uli/na  :mrgreen:
(local language)
Oh yeah!
ejbasses
bumperooney
hehe nice one zener
Please gotta have a schem of one of these things.
calling all bassists out there? has any body even tried taking a peak inside?
niftydog
yeah, I've pulled the back off.  surface mount, tiny components, incredibly high density circuit... I have no idea what ICs are used. not the kind of thing I'd try DIYing...
niftydog
Shrimp down the pants!!!
cd
Is the circuit not potted (i.e. under a huge black plastic square)?  I was under the impression it was.  If not, I might have to pick one up to reverse engineer.
niftydog
well... haven't looked on the underside of the board, the pot knobs are glued on and I didn't want to go to that extent.  But from memory it's a dual layer board with SMD on both sides.  Parts of it may be potted.  I'll have another look if you like... but I think you're talking fairly intense project here!
niftydog
cd
No need to go to any trouble, I was mostly thinking out loud.  If a schematic is going to surface, it's not going to be through me - my rule of thumb is that if it's going to be more expensive to clone than to buy, forget it (used ones go for $100-125).
moosapotamus
SABDDI
Yeah, I wouldn't expect a scheme of this one to be surfacing any time soon.
~ Charlie
moosapotamus.net
ejbasses
that isnt too DIY friendly is it?
hehe
I guess ill just have to save up for one. Ill build the GT2 instead.
J. Luja
QuoteYeah, I wouldn't expect a scheme of this one to be surfacing any time soon.
Well, not unless I can get my hands on one. It does look more simple than the gt2, but I don't know anyone that has one that I could borrow.
-Jeremy
Fp-www.Tonepad.com
If anyone can pull this one off it's J Luja!
I'll be waiting for the schem to make the layout ;)
Fp
www.tonepad.com : Effect PCB Layout artwork classics and originals : www.tonepad.com
cd
How do you get around the block of epoxy?
casey
on the bottom left hand corner of the circuit board, it looks as if
it has a couple of bad solder joints that needs to be fixed....  :)
try this link out, it's not the sansamp, but it might be better:
http://www.albertkreuzer.com/pics/el/pre/schem/preamp_sch21.gif
Casey Campbell
J. Luja
QuoteHow do you get around the block of epoxy?
soldering iron at 800 degrees with a chisel tip I don't mind getting ruined
dental picks
scalpel
lots of ventilation
the board looks like this when I'm done
http://www.axiomdrift.com/schematics/DD%20board.jpg
ejbasses
Some body get J. Luja an SABDDI quick!!!!!
well J. Luja i guess my fate is in your skillfull hands.
mikeb
I'd be pleased to tryout any pcb layouts (or just build it from a schematic); this bass player can be 'cheap' as much as any of you guitarists .... ;)
Mike
Ansil
Quote from: J. Luja
-Jeremy
i have someone who is willing to let you look at theres and no epoxy on the back of it either.. haven't seen the front completely but from what i have seen it is not epoxied.    email me.  or reply to the pm i sent ya.
