CA3094 Substitute?
Started by toneless, June 10, 2004, 03:36:30 PM
toneless
I can’t find the IC CA3094 but I’ve read in the forum that I can make one
using a CA3080 and a FET.
Can anyone tell me how to build a CA3094?
AL
ExpAnonColin
I hear that the LM13700 is a possible substitute (not direct, the 13700 is a dual).
Also, a CA3080 plus a darlington follower:
Would work.  You could try 2n2222s or 3904s and go from there.  I'm not sure what Re should be in this case, anyone?
-Colin
puretube
toneless
Quote from: anonymousexperimentalistI hear that the LM13700 is a possible substitute (not direct, the 13700 is a dual).
-Colin
Thanks.
Could you tell me where I conect the Vin and Vout?
mikeb
Do a search in the archives of this forum - there's a large body of information on OTAs and substitutes for the CA3094. FP / tonepad has documented the subtitutes in his/their Small Stone or Ross phaser build - check it out!
Mike
ExpAnonColin
Vin is basically from the output of the opamp, Vout is the new output.
-Colin
