bypass switching and battery drain
Started by cove, June 13, 2004, 12:09:13 PM
cove
with general guitar gadgets bypass switching...
http://www.generalguitargadgets.com/v2/diagrams/mixer_lo.gif
will there be battery drain if i leave the input cord always plugged in?
just another example
http://www.generalguitargadgets.com/v2/diagrams/bmagic_lo.gif
with the bmagic bypass if i dont leave the effect on but leave the input plugged in will there be drain...?
thanks
Yes, until the battery is disconnected the current will flow.
SoundTech
The thing about true bypass wiring is that it doesn't really turn the effect on and off, it just takes the inputs and outputs and connects them to each other, or to the effect.  The effect is always on.  The only way to turn the effect off is to kill the power to it.  In the mini mixer example, if there is NO power supply connected to it, and it's just running off the battery, then removing the cable plug from the output jack will disconnect the ground from the battery to the circuit, and will stop the flow of current.  In the Blue Magic example (again assuming NO power supply), removing the cable plug from the input jack will disconnect battery ground.  In both cases, they are using a stereo jack to make a ground connection to the circuit.
Sound Tech
  (((O)))
