2P4T Rotary Switches
Started by tplyons, June 15, 2004, 09:59:48 PM
tplyons
Anyone know where I can get a 2P4T rotary switch for my MXR Phase 100 I'm building? I'd like to keep the rotary, but will use a toggle if I have to.
\m/ Timothy Lyons
Fret Wire
http://www.mouser.com/index.cfm?&handler=data.listcategory&Ntt=*2p4t*&terms=2p4t&Dk=1&D=*2p4t*&N=0&crc=true
http://www.apem.com/
This might be what you're looking for. For future reference, when you need something like this, go to Mouser or Digikey and enter the component type in the search field. I just entered "2p4t". It may or may not always work.
BTW, I believe the phase 100 uses a 4PDT selector anyways.
http://www.mouser.com/index.cfm?&handler=data.listcategory&Ntt=*4pdt*&terms=4pdt&Dk=1&D=*4pdt*&N=0&crc=true
Fret Wire
(Keyser Soze)
tplyons
Quote from: Fret WireBTW, I believe the phase 100 uses a 4PDT selector anyways.
Okay. The 4PDT Selector, are you sure?
This is what I get from the layout I found:
I desperately need one of these or a replacement with a diagram of how to wire it.
\m/ Timothy Lyons
Fret Wire
That is a 4PDT switch. That's from GGG, correct? You can double check with J Sleep. He can recommend the exact switch from Mouser.
http://www.generalguitargadgets.com/v2/bom/mxr100bm.txt
Fret Wire
(Keyser Soze)
tplyons
Yep. Lined it up to my circuit board and it looks exact so I trust it. Now where's J Sleep when you need him?
\m/ Timothy Lyons
Fret Wire
Are you building a new pedal from GGG's pcb, or are you repairing an old MXR?
Fret Wire
(Keyser Soze)
tplyons
Closer to the second. I aquired a NOS populated Circuit board and would like to make it come alive.
\m/ Timothy Lyons
Samuel
Fret Wire are you sure? Sure seems like it would be 2P4T
Fret Wire
That's what JD calls for in his material list. And that switch looks like a 4PDT to me. I could be wrong, that's why I told Tplyons to double check with JD. I belive it's just a terminology difference. I'm real curious myself, I have a block-logo phase 100, plus a nos board also.
Fret Wire
(Keyser Soze)
Fret Wire
Fret Wire
(Keyser Soze)
smoguzbenjamin
That's a double pole 4 throw switch mate ;)
tplyons
Well, I bought the Lorlin. Any Idea what I can do with the other 2 positions?
\m/ Timothy Lyons
Fret Wire
It comes with a tang washer that lets you select the number of posistions. When you set it to 4 posistions, it won't turn to the last two. Maybe Mark Hammer knows of some mods for the last two if you want them.
Fret Wire
(Keyser Soze)
soundcollage
If you are drilling your own enclosure I highly recommend Mark Hammer's 5 knob mod. Search the forum and you'll find plenty of ideas. The stock switch is fairly limited and even if you only replace the four way switch with two knobs for depth and resonance (three total), you can dial in significantly more tones. Plus, if you havent bought the switch, two alpha pots only cost about $2.50 which costs less than the switch.
james
tplyons
Too late. It sounds cool but my buddy asked for a Phase 100 clone, no mods. He loves the thing, just can't afford it.
\m/ Timothy Lyons
