I call it Twang Banger but I need some help
Started by jneely, June 23, 2004, 12:18:05 PM
puretube
when all is balanced out, you should hear vibrato, when twisting the pot fast....
jneely
http://img78.photobucket.com/albums/v255/JNEELY/twangbanger3.jpg
Hi guys .
I removed the 1uf and it stopped working all together. I already had the balanced s/d and that really didn't sound any different.
How do I blend dry signal. I fed input to ouput with a small resistor and it squealed like a pig.
I should mention that since I placed the .1uf caps on it no longer drops or loads when it's driven by my other pedals.
Jeff
jneely
I do hear the point where the circuit rolls over from bass to treble currently.
gez
Quote from: jneelyHow do I blend dry signal. I fed input to ouput with a small resistor and it squealed like a pig
With most phasers it's usually done by mixing the output of an input buffer with the output of the phase-shift stages.  Usually done passively, a resistor from each output (usually equal value) combine and the junction is fed to an output cap (pulldown resistor on output).
Personally, I prefer an active mixer (op-amp, though you could use a discrete version).
Look at some phaser schematics and you'll get the idea.
The squealing pig effect was probably due to you adding gain in the second stage (and perhaps how you did the mixing?)
