Feedback on ROG pcb layouts
Started by Gringo, July 13, 2004, 10:27:41 AM
Gringo
I'm sure there must be someone out there that has used at least one of the layouts i drew for the great people at runoffgroove.com.
It would be great to have your opinions, questions, or corrections (what corrections? I KNOW they're perfect :twisted: )
Cut it large, and smash it into place with a hammer.
http://gringo.webhop.net
Fret Wire
I did the Fetzer Valve. Your pcb layout works fine. Nice and small. I haven't redone any of the amp sims over from perf to pcb, but I'm planning on it. They're all unboxed still. I like to use the 1590b wherever I can. You lay them out tight, with no wasted space, which I like.
I"ve got a lot of photo board coming in, so I'll be redoing the 18, and Supreaux first. I'll let you know when I'm done.
Thought about a pcb for the Tube Reamer? Nice sounding pedal. Small, simple perf job, but it deserves a nice pcb layout small enough for a 1590b.
Fret Wire
(Keyser Soze)
mikeb
If people point me towards schematics I'd be happy to do PCB layouts as time permits, especially simple designs (few opamps or transistors or less).
Mike
Gringo
QuoteThought about a pcb for the Tube Reamer? Nice sounding pedal. Small, simple perf job, but it deserves a nice pcb layout small enough for a 1590b.
I don't know what dimensions a 1590b has, but i think that you might get your wish...soon ;)
Come on, folks, i know using a pcb is not as "tough" as perfing your way through, but you can admit it here, nobody will laugh, promise  8)
Fret Wire
Quote from: Gringo
I see you did it! :D  :D . Thanks!
http://www.runoffgroove.com/tubereamer.html
Nice and small, that layout will go in a 1590b no problem. A 1590b is the MXR size. You'll get another build report soon. Circuit Specialists is slow on this order. I ordered some photo board and trimmers on the 8th, and the delivery date is the 20th. They're not usually this slow.
Here's the specs on the Hammond boxes:
http://www.hammondmfg.com/dwg.htm
Fret Wire
(Keyser Soze)
