Silver Solder Mojo
Started by Mobisimo, July 14, 2004, 10:58:17 PM
Mobisimo
Quote from: Fret WireBTW, Mobisimo: We're not goofin' on you. Just having some fun with the pedal maker's hype. Given the amount of hype that some of the boutique pedal makers use in their advertising, it's a perfectly legit question to ask. We're more than happy to help you save money on equipment, so you can spend your money on what really counts: components to make more pedals! $8 for a whole pound of good solder, it'll last you quite a while.
No worries, man.  I can appreciate that.  I half suspected a TS clone anyhow, but I figured whats the harm in seeing if theres a difference in solder.  I was listening to some sound samples on a site which weren't particularly impressive (granted, its over the internet quality), but there was a fair discrepincy between the samples and what the guy thought of it.  Not to mention, the inside was a f*ckin mess.
What is impressive is how a 400 dollar price tag can be so alluring as to make one think that it is worth the money.  Had me goin for a bit...
bobbletrox
I recently switched to Sn 95% Sb 5% tin solder, partly because it's lead-free, but also because it's made locally.  It has a different "feel" than regular solder though -the melted solder is a bit more gooey.
Alex C
Quote from: Ge_WhizHuh, cheapskates - skimpin' on the gold plating...
Gold PLATING??!!  Blasphemy!  Surely you meant "solid gold conductors with interwoven platinum 'energy rods' to let the sonic aura of your equipment shine through as nature intended."
Alex
edit:  Remember this?   :D http://diystompboxes.com/sboxforum/viewtopic.php?t=18667&highlight=audiophile+knobs
I'm going to start bolting everything down with Gold lugs and Nuts...'conduct' surveys on the marketability... :lol:
niftydog
that's not so funny. I saw a serious project for an ultra-low distortion amplifier that specified brass screws for the PCB. The PCB was such that a ground plane made contact with the screws, and hence the cabinet. Apparently, dis-similar metals caused a noticeable rise in the THD for the amp!!!
niftydog
Shrimp down the pants!!!
brett
Quotenoticeable rise in the THD
And as machines can detect less and less THD, the audiophiles will want lower and lower THD.
Strange that the same people are typically unable to detect poverty in India and Africa.
Brett Robinson
niftydog
just like this guy
This absolutely disgusted me when I read about it. That kind of money could go a long way... but no, they buy a tiny little, useless, unattractive painting!
niftydog
Paul Perry (Frostwave)
Quote from: mikebAhem ... solder is *supposed* to be a mechanical / supportive device, it *isn't* supposed to be used for conduction.
....ahhhh...I've seen exactly the oposite argued somewhere!  Anyway, for the stuff we're doing, it hardly matters, IMHO.
gez
Quote from: niftydogjust like this guy
Well, admittedly she's no oil painting...er, no that's not right...anyway, it is a few hundred years old, and it is by Vermeer! (a pretty amazing artists, someone who cronicled lives/scenes of ordinary folk)
In an ideal world all this stuff would be in galaries and not in the hands of private collectors though...
Have you seen 'Girl with a Pearl Earring', the film based on Vermeer's life? (well, a bit of it).  Good film....I'm still waiting for the XXX version...
csj
2% and 4% silver solder is available at Rat Shack. Right down the aisle next to their ass-branding soldering irons.
Whether it makes a difference or not probably depends on if you're trying to cloud the fact that you've basically ripped off everything you've built from somebody else. It becomes important only when you've got to come up with something, anything, which you can use to rationalize your ripoffs.
If you're going to use silver solder and you want to be a tone guru just follow these easy steps...
1. Rip off someone else's good circuit,
2. Emphasize the trivial (silver solder, carbon comps, 90% right angle wiring - regardless of current flow-) etc...
3. Justify by quoting from Ecclesiastes..."there's nothing new under the sun".
4. Assume everyone who listens to you is an electronics idiot and condescend to them as much as possible.
5. Pray you don't get exposed or it's back to laying concrete.
I know GrandLaff lurks here.
Some thanks to him are in order.
I'd like to thank Jack Orman for GrandLaff's TS values.
I'd like to thank Zachary Vex for Grandlaff's Mosfet Boost.
I'd like to thank Leo Fender for GrandLaff's 20 watt amp. A rebiased and repowered 5E3 clone using 6L6 tubes.
I'd like to thank Kevin O'Connor for GrandLaff's Plexi.
His "Mo D" distortion is the run of the mill modded ProCo Rat.
His Wah pedal is a stock repro of a basic Vox except with a Red Fasel and a 51k input resistor instead of a 68k.
When is silver solder really important? Only when you can't tell the difference between OhmS law and Cole Slaw.
The reason his pedals/amps sound good (and they do) is because the circuits he clones are good. It's just that simple.
troubledtom
hey guys,
  i use silver solder. i used to work for minolta, repairing underwater cameras. they used it and i still do. i got the job right after electronics
school and never changed. it works great for me. i'm in the bizz and never consindered it a selling point. ...........  and never will.
  whatever floats your boat :D ............ some guys are leg men , some guys are tit men. who's right......? .......i prefer both :twisted:  8)  :wink:
         peace,
           - tom
guitonit
I am probably going to open myself up for a lot of ridicule here because I have no "scientific evidence" to back this up, but here is the experiment I conducted.  I have made three "Grandlaff" Boost's.  The first was done  entirely with 60/40 solder.  The second one (made with identical 5% tolerance parts, sorry I don't have the measurements of how close they are within the 5%) was made with the same 60/40 on all circuit board connections, and Kester silver solder on all connections within the box (ie. input and output jacks, connections to the pot, and power) and the last one I made (once again with same 5% tolerance parts), was silver on all connections.
Did it make a difference?  Sure did.  I put all three of them together in a  side by side test, same guitar, same amp.  It went from dull sounding, to middle of the road, to fantastic (silver being the best for those keeping score at home).  Sure it costs a bit more, but IN MY OPINION (remember folks, we all can have our own opinions here) it is worth every penny.  All I can say is, it made a HUGE difference to MY ears.
Alright, commence flamming!!!
SA
What do you mean the tour is over?
javacody
EVERYTHING matters in this kind of stuff. It's just deciphering HOW MUCH it matters.  :)  I use silver solder. Why? Because, when I first bought solder, I didn't know my ass from a hole in the ground about electronics (still don't!) and I still have the original spool. Now, take a basic TS type circuit, put in better caps, better resistors, better jacks, better pots, better opamp, better transistors, and use silver solder, and I bet you are going to have a damn fine sounding pedal. But, how much better will it sound than an off the shelf TubeScreamer? Who knows? And I'm not about to spend the next year finding out.  LOL
Also, regarding how easy certain types of solder are, if you have a clean iron, clean components, and your iron is the right size/temperature, then I would say ANY solder will do you right. I will have to take your guys' word that some solders are easier to use than others.
Also, why the hell would you claim silver solder's better tonal benefits and then throw in the noisiest resistors you can find (carbon comp)? So you can more clearly hear the hiss they are producing? HA HA HA Poking fun at this LandGraff guy.
mikeb
Quote from: guitonit
SA
Ok - sounds like complete b/s to me! (well, you asked for it) :D Are you saying the difference between the first and second one was only parts tolerance? Besides that - it wasn't a blind test, and you knew what was in each one, so are you surprised you found the 'best' one to sound 'best'?
Too many people spend too much time looking for that 0.001% improvement in their tone when they should be practicing. I don't seem to recall any silver solder being used in Hendrix's pedals, or SRVs or ......
As mentioned previously, if you need to use silver solder as a selling point, you must be hiding something, or your 'work' must be completely unremarkable.
Mike
Somicide
personally, i used silver solder from the beginnging, til it ran out recently.  Then, I switched to this hug spool of 60/40 i found.  Difference?  well, between you and me, all my solder was used as brazing basicly, to glue stuff together after they were mechanically connected.  differences are the 60/40 rosin core flows easier than the silver solder, and i cant pull a new length of it from the spool with my teeth because it stays hot longer.  thats about it.  MY few cents anyway.  Peace N Love,
Jeff
Peace 'n Love
Quote from: Somicidei cant pull a new length of it from the spool with my teeth because it stays hot longerJeff
Sounds more like 'suicide' than 'somicide'!! If you ever notice a blue line around your gums, you'll know you have passed lead absorbtion criticality.
black mariah
Quote from: Paul Perry (Frostwave)
I always use small lengths of solder instead of one big one (easier to maneuver in a guitar cavity). One day I noticed that I was, without thinking, holding it in my mouth when I wasn't using it. :shock: Smart, eh? I stopped immdiately and thus far only one of my testicles has fallen off.
:roll:  :lol:
ErikMiller
Quote from: gezHave you seen 'Girl with a Pearl Earring', the film based on Vermeer's life? (well, a bit of it).  Good film....I'm still waiting for the XXX version...
Which I guess would be Girl With a Pearl Necklace?
Forgive me....
gez
Quote from: ErikMiller
Forgive me....
What's wrong with these people, don't they know when to look a gift horse in the mouth?!!!  Google it, it simply doesn't exist!
Well, it didn't the last time I looked...not that I look for those sort of things...er, I mean if you did do something like enter those words into a search engine...er, probably nothing would turn up...
Phew, think I got away with that one!
jrc4558
He he he
Haw haw haw
Se how the fly like Lucy in the sky
See how they run...
