Sequencer: only 2 steps working?
Started by bobbletrox, July 15, 2004, 11:02:48 PM
bobbletrox
I perfed the sequencer up and connected it to a PWM perf -but something's not quite right- I can only seem to only get 2 steps working so it just sounds like a weird tremolo effect.  It sounded like I managed to get all 8 steps working briefly by gently pressing the solder side, but after reheating all the joints and making sure they were good, it still only goes 2 steps!  I gave up in frustration when the +9v wire finally broke off from all my wire jiggling and sent a loud spike through my amp.
The crazy thing is that it does cycle back and forth between steps 1 and 3...which it shouldn't be able to do by my understanding.  I just...don't...get it.
Arno van der Heijden
Try installing the other two 100k resistors between the cd40193 and v+.
I don't know why, but it made a difference for me....
bobbletrox
http://www.geofex.com/FX_images/ud-rand.gif
Do you mean the 100k resistors on the CD and -Ld pins?  Which pin is -Ld on a CD40193 anyway?  The TI pinout is slightly different than the 74C193:
http://focus.ti.com/lit/ds/symlink/cd40193b.pdf
Yes, those are the ones. Mine did the same until I connected those resistors.
The -Ld pin is # 11. Look here:
http://www.musicfromouterspace.com/analogsynth/new32x1and16x2sequencer.html
bobbletrox
Thanks!  :o
I hooked 'em up and now 4 steps work lol.  Four out of Eight ain't bad I guess.  I'll keep at it and see if I can get the others to work...
Here's what 4 steps sound like controlling a PWM: sequenced-pwm.mp3
I might post this sample on the Harmony Central effects page to see what pedals users think...because I was really just interested in the electronics side when choosing this project.
Jason Stout
Jason Stout
mikeb
Quote from: bobbletroxI might post this sample on the Harmony Central effects page to see what pedals users think...
"Cool - how much?"
"When can you make one for me?"
(then you tell them a reasonable price and ask if they are REALLY interested)...
...deathly silence...
:D
Mike
Quote from: bobbletroxThanks!  :o
Mine does all eight steps, so there's still something wrong I guess....
LinuxMan
Hi.
I was wondering if you still have the problem with the above layout?
The thing is your 40193 (IC2) is wired incorrectly. Move the pin #5 wire
(which is a count up timer) to pin #6 (O3). And you're there.
I did the sequencer with your layout and it works now (all 8 stages). I
changed the 47k resistor to 4.7k though. Gives me more speed...
I hope that helped... Nice redraw of a circuit btw. You could fill in the
corrections one day (100k to voltage + wrong pins) and repost the thing.
Cheers
LM
