Real McTube II Questions
Started by Paul Marossy, July 17, 2004, 03:47:36 PM
Paul Marossy
Has anyone here built the Real McTube II?
I have a question about the two pots:
On RV1, do I interpret that as having the lugs 1 and 3 connected directly together? I don't understand how this would work - it looks like it would ground the signal! Is this supposed to be a variable resistor?
And on RV2, there appears to be a 100K resistor connecting lugs 1 and 3 together, right? So that would be in parallel with the 500K pot?
Would there be a problem if I used 1M pots instead?
Here is the schematic:
http://www.dogstar.dantimax.dk/tubestuf/graphics/mctube2s.gif
Any help much appreciated.  8)
Fp-www.Tonepad.com
That 'ring' around the connection means to do it with shielded wire and ground only one end.
Fp
www.tonepad.com : Effect PCB Layout artwork classics and originals : www.tonepad.com
lightningfingers
USE SHIELDED WIRE!!
Seriously, mine at best sounded noisy when it was on, it wouldn't even consider being bypassed until I used shielded wire. [/b]
U N D E F I N E D
Paul Marossy
Thanks. Based on my Shaka Tube experience, I was planning on using shielded cable. So, that 100K resistor on RV2, it's across lugs 1 & 3?
Fp-www.Tonepad.com
yes.
Look here for more info on the real mc tube (permission granted to me by Fred to make this project).
http://www.tonepad.com/project.asp?id=23
(I haven't built it though)
Fp
Paul Marossy
Paul Marossy
One more question:
On the schematic, it shows Pin 4 & 5 of the 12AX7 connected to the 12.6V power supply, and Pin 9 grounded. Does Pin 9 actually get connected directly to ground? I thought that normally Pin 9 is left unconnected, at least on an AC heater scheme. But does that change with a DC heater supply?
I'm almost done, I just have to get those two 33uF/160V filter caps...
I've got it in a 6"x6"x2.5" high enclosure. Since I really like the clean to mild tones, it's going to be kind of a standalone tube preamp thing that will get a little wood enclosure wrapped in Tolex or something and a little carrying handle.  8)
