Detented potentiometers
Started by bwanasonic, July 20, 2004, 12:30:30 AM
bwanasonic
I'm getting together parts for a TS type OD, and am interested in using the 11 position detented pot featured on some boutique pedals.
Two questions:
- Where can I get a 1M 11 position detented pot
- Having never actually used one, is this a useful feature?
It seems like a good idea for live performance and just generally appeals to me.
Kerry M
mikeb
Sorry I don't know where you might get those in the USA - however, if you are going to go that route, you might still consider using a 12-way rotary switch. This way you can 'program' your own settings by careful resistor selection (using a detented pot you would be limited to equidistant settings spread across the pot range). The only (slight) disadvantage with this method is that - as most rotaries are break-before-make - you might get a 'pop' or other effect through the circuit, depending on whether the switch is used to configure tone, gain, volume etc; with a detented pot there isn't any 'break', so this doesn't happen.
HTH
Mike
phillip
Mouser Electronics.  1M linear taper 16mm pot w/ 11 detent positions, part number 313-3000-1M.  $1.74 each.
Phillip
bwanasonic
Thank you much! I searched Mouser, but obviously not well enough!
Kerry M
