How do i 2 LPB internally?
Started by Hydesg, July 24, 2004, 06:51:11 PM
Hydesg
hi
how do i connect 2 LPB2 together internally?
as in
guitar - > input - > LPB2(1)_output -> LPB2(2)_input -> output - > amp
using 2 dpdt switches
so that i can by pass either one when i wish to
RDV
If you're using 2 DPDT switches then you wire the first one up normally to the 1st LPB except don't hook the wire to the output jack from the switch. Instead hook it where you would normally wire the input jack for the second switch, then wire the rest of the 2nd LPB and 2nd switch normally. You'll then be able to turn both on or off individually, but when you have them both on the first will be feeding the second one, so the 2nd LPB volume will be the master volume and the 1st will be the pre-volume.
HTH
RDV
ildar
Can this be done with an (theoretically) unlimited chain of effects?
RDV
Quote from: ildarCan this be done with an (theoretically) unlimited chain of effects?
Yes, but remember that if on, one feeds the next(& so on).
RDV
audioguy
I tohught I had read on someones webpage that you needed to remove a cap on the out of the 1st unit or the in of the 2nd?
RDV
Quote from: audioguyI tohught I had read on someones webpage that you needed to remove a cap on the out of the 1st unit or the in of the 2nd?
Perhaps if you're putting 2 effects in series on one switch, but we're simply talking about a multi-effects box with separate switches for each effect(in series).
Regards
RDV
Hal
well, its not that you would _have_ to, but input and output caps between the two _could_ be reduced to one cap between the two stages.  it would be easier, and work just as well, to simply make the output jack of the first, the input jack of the second, if you know what i mean...
RDV
Quote from: Halwell, its not that you would _have_ to, but input and output caps between the two _could_ be reduced to one cap between the two stages.  it would be easier, and work just as well, to simply make the output jack of the first, the input jack of the second, if you know what i mean...
Yes, but only if you're putting two in series on one switch.
RDV
Hal
welll.....
at first i was thinking one single "true bypass" switch, then another SPDT switch to make it single/double...
but now i see what you're talking about.
ildar
Somewhat on the same track-how would you go about powering several effects with one source, in this case a dc wall wart?
RDV
Quote from: ildarSomewhat on the same track-how would you go about powering several effects with one source, in this case a dc wall wart?
Parallel them.
RDV
