Orman is the MAN
Started by Somicide, August 01, 2004, 06:48:26 AM
Somicide
Out of curiousity, I built the "Muffer" from his page, which it explains is a BMP stage.  I built it on a PCB the size of a quarter, but square.  Nice dirty sound, real loud, just lacking in highs.  Good fun though.  Peace N Love,
Jeff
Peace 'n Love
Elektrojänis
The lack of high frequency content might be because of lowish input impedance. You could probably get more highs by placing a simple fet booster before it. It would probably not make the circuit too much bigger. It wouldn't be as simple then though.
Edit: Driving it with a fet booster might make it harsh though as the lowish input impedance (that is loading the pickups) might be smoothing the sound (like in FF and others).
brett
Hi.  You can lift the input impedance a fraction by putting a resistor in series with the input (as per boutique FF), or lower the emitter resistor to, say, 100 ohms.  That'll boost gain a fair bit, which you might not want.
good luck
Brett Robinson
Elektrojänis
And ofcourse the common tweaks of changing the input and/or output caps to smaller values will make a brighter sound. Smaller input cap might make the drive level a bit lower though.
Somicide
This thing has gain to spare, so i don't think a loss would be too bad.  How much would it go down if I put in say a .1 uF?  Peace n Love,
Jeff
Peace 'n Love
Elektrojänis
I'd try 0.1µf on the input side for starters. It might not cut bass that much though so you might need to go even smaller values.  BTW. It will change the tone of the distortion too.
BTW. Jack Orman is the man. He's been doing this stuff for a very long time.
mikeb
Hopefully Jack will come out of 'retirement' soon!
Mike
David
Quote from: SomicideThis thing has gain to spare, so i don't think a loss would be too bad.  How much would it go down if I put in say a .1 uF?  Peace n Love,
Jeff
Jeff:
What transistor did you use?  I built one with a socket so I could experiment.  When I put a 5089 in there, I got a screaming, gain-laden monster!  Now that you mention it, though, it does seem a little "bassy".
Gilles C
It's a fact that it's not ear piercing like some other Treble Boosters.
I would say it's just a helper more than a booster for the highs.
I used it a few times just to take some bass out of my guitar that is quite bassy, and it was ok for me. But just because I don't really like Treble boosters...  :oops:
But a little more treble would be nice...  :wink:
The one I built:
Useful in an effect loop.
Gilles
Elektrojänis
Muffer a treble booster?
Ben N
That would be the Muff-master, which, IIRC, is on the AMZ cd.
Gilles C
It is also on the site
http://www.muzique.com/schem/projects.htm
But I just realised I was thinking of a different circuit than the one in the original post...
This is what I built.
It can help modify the real Muffer.
Somicide
David,
I used a 5089, love em, and I've got like 50 lying around sooo...  good choice!  I think I will lower the input cap.  Another though, could all this be done with a 2n7000 as well?  I ask because I have a few of those lying around too.  Peace n Love
Peace 'n Love
Elektrojänis
Oh... Don't forget you can try to tweak C3 too.
Also putting somethin like 1µF - 4.7µF cap parallel with the R4 might boost treble a bit.
