Temporary mute circuit to avoid gain stage popping?
Started by Frost, August 01, 2004, 08:10:29 PM
Frost
Hi there,
I've got a guitar amp with a gain stage that can be switched in or out. Problem is, since it uses a series switch, the stage pops when I switch in or out. I'd use a shunt type switch but I'm unhappy with the tone degradation of the isolating resistors, etc.
Can anyone recommend a very temporary mute circuit to mute the output of the amp when the relay for the switching gets engaged? Can I use a 555 CMOS delay for this or a CD4049 as a flip-flop type circuit? Many thanks,
-Heiko
Travis
How about shunting with a power FET?  It should help you lose the clicks/pops and reduce or eliminate signal degradation.
Frost
Hey Travis,
Thanks for the suggestion. I spent all day yesterday banging my head into the wall trying to come up with a complex solution. I was not until I was brushing my teeth getting ready to hit the hay that I thought of what you suggested...using a transistor activated by the momentary switches that trigger the 74C373 to just shunt the signal in the amp to ground. Anyways, thanks again!
-Heiko
Travis
Frost, RG does something similar in his automatic mic muting article.
The photoFETs almost certainly can't handle the voltage you need, but the idea is there.
http://www.geofex.com/Article_Folders/automike/automike.htm
Frost
Hey Travis and everone else,
I'm using a 2N3904 NPN transistor to ground the signal in the amp at the entrance to the phase inverter. Is there a better transistor that you can recommend? I'm still getting a little bit of pop coming through...
Thanks,
-Heiko
niftydog
You're sure you're getting full saturation?
I've never done this, but I would hazard a guess that a MOSFET would do a better job.
niftydog
Shrimp down the pants!!!
