Zero Ohm resistors/jumpers
Started by Fret Wire, August 09, 2004, 03:41:53 PM
Fret Wire
Fret Wire
(Keyser Soze)
jimbob
Im still new to this but whats the point to using 0 ohms? Isnt that the same as
a jumper? I know ive had a crybaby that used one..It simply had a black line on it..i never understoof why..
thanks
jim
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
mikeb
0 ohm links are handy for manufacturers as they have the same format as resistors for design / layout purposes, and hence can be more easily stuffed into PCBs; also otherwise the assemblers would need to cut and hand-form wire links which just simply isn't financially efficient.
These days if you need more than a few jumpers on a single-sided board then you might as well go double-sided, as the increase in price over single-sided production is minimal, or might even be zero.
FWIW, I can get 1000 0-ohm links for AUS$5, so I don't know if that price is that great. .... but it's only 1c or less per unit, so is cheap anyway! :)
Mike
toneman
they help in disguising the circuit.
also, bogus "wires" with copper removed,
and colored insulation superglued to
a random, or better, a "stratigeic" terminal.
:twisted:
cloners Bware!!
staytuned
tone
