onboard preamps!
Started by nero1985, August 13, 2004, 11:10:13 PM
nero1985
does anybody know anything about onboard preamps for guitar that can give me boost or cut of MIDS????
Alpha579
for mid boost, you could try the Eric Clapton mid boost preamp...
Alex Fiddes
Small EQ and distortion changes in early stages can have large influences on later stages.
 Tune the Booster to the Chain, this includes Guitar, effects, amp.
 Depending on the circuit and the transistor used, many different boost tones are available
 I use:
 Fetzer Valve  Jfet
 Stratoblaster  Jfet
 Mini-booster  Jfet
 Mosfet Boost
 Dual Clean Mosfet Booster
 Rangemaster Ge PNP
 Vox reble Booster Ge PNP
 Brian May Treble Booster Si NPN
 Micro Amp JRC 4558
 ???????????? All have at least one sockketed cap and transistor.
 J201 Smooth can be clean-ish / high end sparkle
 Mosfet Big CLean Loud
 Ge transistors impart tonal characteristics including EQ and Distortion, probly a bit 'bias finicky' for onboard guitar use
 ...Current consumption?...
 ...Bypass?..
 For mids cut: Notch Filter or Tone Control...[   ]
 For mids boost: Smaller input cap or cap in signal path cuts bass [LP filter], cap from signal path to ground [HP filter], cuts highs..tune for desired midrange boost response
onboard
Quote from: petemooreSmaller input cap or cap in signal path cuts bass [LP filter], cap from signal path to ground [HP filter], cuts highs
Wouldn't the filter flavors be named the other way 'round?
Cap in signal path cuts bass (HP filter)
Cap to ground cuts highs (LP filter)
Maybe I'm all mixed up.....just trying to understand high and low pass....
High pass cuts lows, low pass cuts highs, right?
-Ryan
"Bound to cover just a little more ground..."
Nope you got it right...typo sorry
 anyway ''socket' when in doubt... :oops:  8)   Dohh...lotta help I am sometimes...
onboard
I'm curious what this        Musitech preamp circuit is...gotta love that shrink wrap job. :wink: For $80 I won't be buying one to trace anytime soon, though it's gotta be a good circuit for StewMac to carry it.
-Ryan
