Easy question
Started by jimbob, August 19, 2004, 04:56:36 PM
jimbob
I was wanting to add a on/off switch to the little ruby- i assume this would be a spst? and where would i connects those leads? :)
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
ezanker
You can use the spst to break the +9V supply.
thomas2
when i made my little gem, i put a mini spdt switch to the hot wire from the battery/adapter.. then added a resistor and a led. ..if that helps  :lol: i even used a wrong resistor.. the led is too dim and i always forget to turn off the amp  :twisted:
tee se itse tai kuole
Paul Marossy
Change the resistor to a lower value and the LED will be a lot brighter.  8)
