ROG Ruby or Little Gem
Started by ildar, August 19, 2004, 11:06:23 PM
ildar
What kind of on/off switch should I use, and how is it wired?
Peter Snowberg
You could just use a stereo jack and connect the battery negative lead to the sleeve contact so that it turns on when you plug in. :D
Otherwise, you could use any switch that stays on. :D Just place the switch in the wire that goes to the battery + side.
Eschew paradigm obfuscation
BILLYL
I put a switch on the back of the volume pot.
BILL
ildar
RDV
Quote from: ildarSo-spdt?
SPST would do it, you're just cutting the power.
RDV
